05-09-2025 03:14 AM
After moving to a new place, my GT-AXE11000 router stopped working normally.
The Wi-Fi LED no longer turns on, and there is no wireless signal at all.
I tried using the ASUS Firmware Restoration tool.
It uploads the firmware in about 15 seconds, but nothing changes afterward.
Another strange issue:
No matter what I do — whether I reboot the router from the UI or simply power it off and on —
it always takes over 10 minutes to finish starting up.
This happens even when I haven’t changed any settings.
I sent the unit to ASUS for repair, but they asked for around 500,000 KRW (~$370 USD),
so I declined and asked them to return the device.
Now I’m back to where I started, and I’m not sure what else I can try.
Just in case, I’ve uploaded the system log here: syslog
Any help or suggestions would be greatly appreciated.
*I'm not fluent in English, so I used a translator. Thank you for your understanding.*
05-09-2025 08:29 AM
Firmware installation should take at minimum 2 minutes. It is not completing the upload.
Did you try manually uploading firmware through the Web GUI? Latest version is 3.0.0.4.388_23883. What firmware version is it on?
Firmware:
Restoration software version 2.1.0.3:
https://dlcdnets.asus.com/pub/ASUS/wireless/GT-AX6000/Rescue_2103.zip?model=GT-AXE11000
05-09-2025 12:57 PM
Yes, I tried both methods, but unfortunately the result is the same.
05-09-2025 01:03 PM
If it's $370 USD to repair, how much is a new one? Amazon sells this router for $329.99 (pre sales tax which adds about 10% where I live). Amazon also sells a used (very good) condition one for $184 (pre-tax).
05-09-2025 01:12 PM
In Korea, the GT-AXE11000 is currently discontinued. So if self-repair is not possible, I’m considering buying the AX11000 Pro from Amazon instead.
05-10-2025 02:33 AM
Were/Are you able to open it to look for anything burned, and/or other internal damage?
Mine is currently running fine but I did not move it (also out of warranty a long time).
05-10-2025 03:03 AM
There were no issues up until the day I moved, but the problem started the next day. I haven't opened it yet, but I don't think there's any major damage.
