GT-AX11000 Pro 5ghz-2 speed issue
springheights
Hey all,  first timer on here.  I've tried searching but i can't find anything on this.  I have recently updated my firmware on my GT-AX11000 Pro and XT12 (x2) and my second 5ghz band is now really slow.  It was running at 600-800Mbps but now im lucky if i get 110, but my first 5ghzz channel is holding strong around 600Mbps even fully loaded.  my slowdown on the second 5ghz band started in May but i didn't put much thought into it thinking git was just my ISP, but I've monitored it over the past few days and its def and issue with the second band.  i updated today to the latest to see if that will solve it but nothing.  Any ideas how i can roll my firmware back to something like what it was when it left the factory?  (im not sure 1 hot to find out what it was and 2 where to get the firmware)
any help would be really appreciated.  I use it for my work and nothing else to keep it clear
4 REPLIES 4
jzchen
Level 16
Are they connected by wireless backhaul or Ethernet?
XT12 Firmware maybe a couple clicks from here:
https://www.asus.com/us/supportonly/zenwifi%20pro%20xt12/helpdesk_bios/
AX11000 Pro Firmware:
https://rog.asus.com/us/networking/rog-rapture-gt-ax11000-pro-model/helpdesk_bios/
Usually 5 GHz-2 is dedicated to wireless backhaul if your system is not wired.
hey Jzchen
thanks for the reply. I have wired the backhaul I’ll update the xt12 but the AC11000 only has the latest firmware 😞
What is the speed of your Internet service?
1gig I’m getting 950 at the modem
