Anyone know if the next BE98 Pro firmware upgrade is going to enable support for WiFi 7 MLO?
Saltgrass
The Windows Insider forum has just released a new build which includes support for WiFi 7.  In order to see those options, a compatible system is necessary, so a new firmware is required to make the BE98 Pro compatible.  It would be helpful, if even a Beta version could be made available.
Thanks for reading.
Maximus Z790 Hero,
Intel i9-13900k
Intel BE200
152 REPLIES 152
s_vanhelsing
The latest firmware is available now. To improve the system efficiency, ASUS highly recommend upgrading your firmware version.
Firmware version 3.0.0.6_102_34491-ge5d05d6_621-g39ad8
- Release note -
New Features:
- Introduced AURA Night Mode.
- Added Multi-link Operation (MLO) network in Guest Network Pro.
- Added automatic WAN/LAN detection feature.
* Please note: After updating to this version, main WiFi encrytpion will be upgraded to GCMP-256 for higher security, please refer to https://www.asus.com/support/faq/1053342/ for more information and setup suggestions.
Bug Fixes and Performance Enhancements:
- Enhanced connectivity for WiFi 7 devices.
- Fixed client binding issues on AiMesh nodes.
- Resolved AiMesh node broadcast issues in Guest Network Pro.
- Corrected Link Aggregation UI errors.
- Fixed Guest Portal bugs.
- Improved AiMesh system stability.
- Addressed DNS errors affecting internet access for Guest Network Pro and VPN connections.
- Resolved the issues of WireGuard client profile names.
- Fixed dual WAN and VLAN 4094 IoT issues.
Security Updates:
- Fixed code execution in custom OVPN.
- Fixed command injection vulnerability.
- Fixed the ARP poisoning vulnerability.
Thanks to the contribution of Xin'an Zhou.
Thanks to the contrubution of Jacob Baines.
- Fixed the injection vulnerability in AiCloud.
- Fixed stack buffer overflow in lighttpd.
Special thanks to Viktor Edstrom.
- Fixed CVE-2023-35720, CVE-2023-48795, CVE-2023-41913
- Fixed the code execution vulnerability in AiCloud.
Thanks to the contribution of chumen77.
- Fixed the XSS and Self-reflected HTML injection vulnerability.
Thanks to the contribution of Redfox Cyber Security.
Love to see this!
Welp....catch you guys again in 6 months lol. (Sarcasm and I hope the next update isn't that far out lol)
MadHatter01
Samsung S24 Ultra still has issues. Connects and then after 1-2 mins, it says connected without internet. I only tested is for 30 mins and in that 3-4 times it did that. I might suggest doing a full factory reset and manually re setting it up. Do not recover from backup.
crashworldtk
After I updated my BE-98 Pro to firmware "3.0.0.6.102_34491-ge5d05d6_621-g39ad8_BA08" it would not connect properly to the WAN. I had to re-apply the "Primary Wan" settings under "http://www.asusrouter.com/Advanced_WANPort_Content.asp"
terrierl
New firmware just hit the asus website for the gt-be98 pro.
https://rog.asus.com/us/networking/rog-rapture-gt-be98-pro/helpdesk_bios/
crashworldtk
I picked up a Wi-Fi 7 enabled motherboard and intend on testing the capabilities. I will report back...
@crashworldtk   If you find, or can't find anything, let us know.  I have been running the advanced Windows build which has support for Wi-Fi 7.
Maximus Z790 Hero,
Intel i9-13900k
Intel BE200
labo
Good news for all GT-BE98 PRO owners. Eric is going to release RMerlin  builds soon 🙂
https://www.snbforums.com/threads/announcement-asuswrt-merlin-support-underway-for-3-wifi-7-routers....
That's good news, the only thing is it voids your warranty correct?
No, warranty will be  there if you restore factory firmware. But no technical support.
