ROG THOR PLATINUM II - 1000W vs 1200W noise levels
br1zz
Hello,
current reviews are not conclusive on that matter.
I am looking for a strong and quiet PSU, i am undecided between the 1000W and 1200W variant of the ROG THOR PLATINUM2
My question is, which one is more silent under the same load ?
MasterC
Community Admin
Community Admin
All the PSUs undergo tests for certifications, you may refer to the results here. You may not know the precise results when the same load is applied to each, but you could extrapolate from the info provided.
FPS, Racing & VR Gamer / Tech Enthusiast / ROG Admin
Daytrader
Thinking of getting the thor 1200w, did you buy one on the end ? thx
