09-12-2024 06:48 PM
I have a problem with my phone. It restarts itself without me touching it, and I don't hear any sound even if I put headphones and Bluetooth Not working and other problems I hope to solve the problem
Solved! Go to Solution.
09-12-2024 08:22 PM
Hi please help confirm information below. Thanks.
1. What is the software version on your phone?
2. Reboot phone to see if issue persists
3. Go to [Settings] > [Apps & notifications] > [See all xx apps] > (upper-right three-dot icon) [Show system] > [AudioWizard] > [Storage & cache] > tap [Clear cache] and [Clear storage]. Then re-confirm if issue persists
09-12-2024 09:29 PM
33.0820.0810.121 (Last update) And I did everything you told me The problem is not solved
09-13-2024 02:02 AM - last edited on 09-13-2024 03:10 AM by Bobby_ROG
Serial number : (removed by Titan_ASUS)
09-12-2024 08:22 PM
09-12-2024 09:29 PM
09-12-2024 11:04 PM - edited 09-12-2024 11:06 PM
Hi version 33.0820.0810.121 is VERY old. Please update to newest 34.1010.0820.88 and re-confirm. Thanks.
09-13-2024 01:28 AM - edited 09-13-2024 01:38 AM
Why when I want to update this appears to me, can you help me?
I downloaded the update but I don't know how to install it on the phone. Can you help me?
09-13-2024 01:54 AM
To upgrade Android 14, you need to update to the latest version of Android 13 first, namely, 33.0820.0810.241. Please go to [Settings] > [System] > [System update] and tap "Check Update". Thanks. If your phone unable to receive FOTA, please provide SN of your phone for me to check.
09-13-2024 03:10 AM
Hi after checking your SN we found that your phone was flashed from CN version to WW version (thus no warranty), thus unable to receive FOTA. Please ask for assistance from where you got this phone. Thanks.
09-13-2024 03:22 AM
Okay thanks Bobby
