Color problem
Mișu
Does anyone have this color problem on ROGPHONE 6
https://rog.asus.com/phones/rog-phone-6-model/
1 ACCEPTED SOLUTION
Accepted Solutions
Bobby_ROG
Community Agent
@Mișu
Hi, if issue occurs on all apps, please try to
1. disable Developer options or any options related to color on Accessibility settings
2. perform a factory reset
Thanks.
5 REPLIES 5
Bobby_ROG
Community Agent
@Mișu
Hi, please elaborate your question. Thanks
Hello @Bobby_ROG ive loaded some pictures yesterday , and If i reebot the phone is normaly , and after few hours somehow the Facebook pictures gooong to be like this ..
 and in any application its like this
I dont know why , in my second phone i dont have this problem maybe its from lăsat update
Bobby_ROG
Community Agent
@Mișu
It's like some abnormal color inversion on some icons, right? Since this only occurs on Facebook, you may try to uninstall and then re-install it to see if issue occurs. Thanks.
That a abnormal color inversion i have on all application ...not even fb🤣🤣
Bobby_ROG
Community Agent
@Mișu
Thanks.
