Strix Scope II 96 Wireless Connecting via Bluetooth or Wireless 2.4
JimmyH
Yesterday I purchased the Strix Scope II 96 Wireless Snow Switch. I am an avid gamer but am about to be doing a lot of typing. The noise of my other keyboard was just too much.
I have the kb connected by USB and am having no luck either pairing it wirelessly or with bluetooth. It won't even allow me to update the firmware on the KB or the OMNI receiver. I follow the bouncing ball but it does not work. It tells me to connect my receiver and my usb cable and press ok, I have done this and it does nothing.
The second part of my problem is getting the keyboard to connect either wirelessly or via bluetooth. It apears in my bluetooth list. However when I flip the switch it disables the keyboard.
The Omni receiver is the exact same as my Gladius III Aimpoint, but I am unable to connect that either.
8 REPLIES 8
Aureliannn_ROG
Customer Service Agent
Hi @JimmyH ,
Thank you for providing detailed information.
To help us troubleshoot the connection issue with your ROG Strix Scope II 96 Wireless keyboard more effectively, we would like to confirm the following:
  1. Connection mode: Are you unable to pair either via 2.4G wireless or Bluetooth? In other words, regardless of using 2.4G wireless mode or Bluetooth mode, the keyboard cannot connect successfully to the computer, and the keyboard information cannot be seen in Armoury Crate? Can the keyboard only be used when connected via a cable?
  2. Bluetooth mode operation: When you want to use Bluetooth mode, have you removed the 2.4G dongle and cable from the keyboard and computer? Ensure that there are no other cables interfering with the Bluetooth connection.
  3. When did the problem start: When did this problem start to occur? Could the keyboard be used normally before that? Have you updated your Windows system, installed new software, or made any adjustments to the keyboard settings?
  4. Other device testing: If you connect the keyboard to other computers or devices, does the same problem occur?
To troubleshoot your issue, we recommend the following steps:
  • Check hardware connections: Pay special attention to whether the OMNI receiver is firmly plugged into the computer's USB port.
  • Reinstall Armoury Crate: Completely uninstall Armoury Crate and then download the latest version from the ASUS website and reinstall it.
  • Update drivers: In addition to updating Windows and chipset drivers, we also recommend that you check and update the keyboard firmware.
  • Reset the keyboard: Please refer to the keyboard's user manual to find the method to reset the keyboard.
  • Unpair and re-pair the ROG Omni Receiver: You can refer to steps 5 or 6 in the following link for more detailed pairing instructions: [ROG Accessory] ROG Omni Receiver FAQ | Official Support | ASUS Global
If the above methods still do not solve the problem, please provide the following information:
  • Computer model
  • Operating system version
  • Armoury Crate version
  • A video recording: Record a video of the process of trying to connect the keyboard so that we can better understand the problem.
  • The solutions you have already tried
  • Armoury crate log
The logs contain detailed information about the software's operation and can help the team identify the problem.
Please ensure that the logs accurately record the occurrence of the issue.
Here are the steps to collect Armoury Crate logs:
Please refer to Q5: What is APP Diagnostics? (New Feature)
https://www.asus.com/support/FAQ/1043747/#a14
Once you have completed the above steps, please upload the collected log files to a cloud storage service and send us the link via private message.
Also, please provide us with your product serial number.
Providing this information will help us locate the problem more quickly and provide you with a more accurate solution.
Providing detailed device specifications (MB/CPU/GPU/PSU, etc.) and the respective driver versions, OS version, and BIOS version will help us analyze the issue more effectively.
JimmyH
Thank you for your reply. I am having trouble taking a video, it always show up dark but I will do my best to answer the questions.
1. Correct, I cannot get it to work in either Bluetooth or Wireless 2.4G. Connected by cable I am able to view it in both devices in WIndows and also change attributes within Armoury Crate. I am unable to do the firmware update though.
2. I removed the dongles and even removed the Gladius III Aimpoint dongle just to make sure there was no confusion. As soon as I unplug the USB cable, it disappears from the list and does not appear when I add device.
3. The problem started right from the get go when I unboxed it on Saturday.
4. I have tried connecting it via Bluetooth and Wireless to my wife's labtop with no luck.
I have gone to the stage where I removed every cable and reinserted them, I have changed USB 2.0 ports. I have done a complete Windows rebuild ensured all drivers were updated. I used Armoury Crate Uninstall and did a complete new install of that including updating everything. The Keyboard will just simply not pair wirelessly or via Bluetooth. I even went as far as turning the PC's wireless feature off.
You mention in the notes to refer to Q5, what is APP Diagnostics. I have no idea what you are talkking about.
How do I attach the LOG DATA? it won't  let me paste the file.
My PC details are as follows:
ROG Strix Z790-F Gaming WIFI II
Intel i7-14700K
64 GB RAM
Geforce GTX 4080
Mouse - ROG Gladius III Aimpoint
Item Version
Armoury Crate UWP App 5.9.4.0
ROG Live Service 2.4.19.0
Aura Service (Lighting Service) 3.07.49
Armoury Crate lite service 5.9.4
Aura Wallpaper Service Not installed
Aura SDK 3.04.43
ArmouryDevice 4.2.0.2
ASUS AIOFan HAL 1.3.3.0
ASUS AURA Extension Card HAL 1.1.0.20
ASUS AURA Motherboard HAL 1.5.0.1
ASUS Ambient HAL 3.4.0.0
ASUS Keyboard HAL 1.2.73.0
ASUS Mouse HAL 1.2.0.97
ASUS MousePad HAL 1.0.3.5
AacVGA 0.0.7.0
KingstonDram 1.1.36
AURA DRAM Component 1.1.26
ENE RGB HAL 1.1.49.4
ENE_EHD_M2_HAL 1.0.13.0
Patriot Viper DRAM RGB 1.0.9.8
Patriot Viper M2 SSD RGB 1.1.0.3
Universal Holtek RGB DRAM 1.0.0.7
WD_BLACK AN1500 1.0.14.0
AIOFanSDK 3.00.15
AiSuiteSDK 1.02.12
GameFirstSDK 6.2.7.0
KeyboardSDK 3.00.62
MainSDK 2.01.27
MbLedSDK 3.00.34
MousePadSDK 1.03.00
MouseSDK 3.01.38
UnifyDongleSDK 1.00.08
VgaSDK 1.00.21
Armoury Crate Plugin - Aio 2.0.12
Armoury Crate Plugin - Keyboard 1.2.36
Armoury Crate Plugin - Motherboard 1.2.20
Armoury Crate Plugin - Mouse 2.3.1
Armoury Crate Plugin - Mousepad 1.2.3
Armoury Crate Plugin - ROG FAN XPERT 4 2.0.12
Armoury Crate Plugin - UnifyDongle 0.0.8
Armoury Crate Plugin - Vga 1.0.4
ASUS Motherboard 4.02.32
GameFirst 1.6.1
ROG BALTEUS Qi 4.01.04
ROG FAN XPERT 4 4.02.04
ROG GLADIUS III WIRELESS AIMPOINT 4.01.13
ROG GLADIUS III WIRELESS AIMPOINT (2.4G) 4.01.13
ROG GLADIUS III WIRELESS AIMPOINT (BLE) 4.01.13
ROG OMNI RECEIVER 4.01.02
ROG STRIX SCOPE II 96 WIRELESS 4.02.11
ROG STRIX SCOPE II 96 WIRELESS (2.4GHz) 4.02.11
ROG STRIX SCOPE II 96 WIRELESS (BLE) 4.02.11
VGA 3.01.05
JimmyH
Aureliannn_ROG
Hi @JimmyH ,
Thank you for contacting us regarding the issue with your Strix Scope II 96 wireless keyboard.
To help you with this issue, we recommend that you refer to the following discussion thread:
Solved: Strix scope 2 96 wireless - update firmware - Republic of Gamers Forum - 1026269 (asus.com)
We suggest that you carefully read the content of the thread and follow the steps outlined therein.
JimmyH
I have an update.
So I managed to update the Scope II to the correct firmware, but my Omni Receiver version differs to other users. Mine is 4.00.02 whereas Nate152's is 6.00.19.
When I tried attaching the keyboard to my wife's laptop it didn't work. I then did a clean install of Armoury Crate Gear to her laptop, a plain old i5 HP running Win 11 Home, and managed to pair the keyboard. This has now proven there is nothing wrong with the keyboard.
So it is obviously something else. My thoughts were the I/O ports. I am meant to use USB 2.0 for both the OMNI receiver and the keyboard, is that right? Nate a moderator has been monitoring this.
Should I reload Windows again???? and only install my keyboard and mouse or something like that? Could the GlaiusIII Aimpoint be causing RF interference?? Why the difference in dongle firmware??
@Nate152
Nate152
I use usb 3.0 ports and works fine.
Now that you've updated to the ROG Omni Receiver with Armoury Crate Gear, uninstall Armoury Crate Gear and install Armoury Crate version 3.2.11.2. - Armoury Crate - Support (asus.com)
Check for updates at the Armoury Crate update center.
JimmyH
I had already removed Armoury Crate Gear, and it hadn't worked. All I did was close iCue and move dongles and cables to USB3.0 connectors and it worked instantly.
Nate152
Awesome,
After so much trouble, it's good to hear you finally got it working.
