ROG Azoth wired connection not workin and not picking up charge
MrWoag
Hello, my ROG Azoth I got in December 2023 has begun to not pick up any charge while wired into my computer or laptop or AC adapter into a wall outlet and the device resets after a few seconds of use, disconnecting and rendering it so that it can't update to become compatible with the OMNI wireless device because the device disconnects and reconnects every few seconds. I tried resetting the keyboard multiple times wit the FN+ESC keys to no avail. Is the issue something that I can replace with a part swap or software update or does the device need to be replaced?
I tried reinstalling armoury crate and updating the receiver, but the program will not work to update the keyboard because it doesn't stay connected for the entire process.
Aureliannn_ROG
Customer Service Agent
Hi @MrWoag ,
Thank you for providing detailed information about your ROG Azoth keyboard.
Based on the issues you've described, we believe there might be a hardware malfunction with your keyboard.
We recommend sending your keyboard to an ASUS service center for inspection and repair.
You can refer to the following sevice center location link:
Official Support | ASUS Global
