Claymore II Battery swelling issue
GreasedLizard
My Claymore II started having issues with certain keys not working properly, or repeating, so on searching the forums, I found posts about the battery swelling, and causing this issue.
I'm out of warranty, so I took it apart, and lo and behold, my battery was also swollen. I removed the battery, and my beloved Claymore II was back to normal again.
Looks like at least the early batches of Claymore II's might have had a dodgy battery. Might be worth investigating, I'm happy to send my battery in to aid in investigations if you tell me where to send it.
Aureliannn_ROG
Customer Service Agent
Hi @GreasedLizard ,
based on your question, may I ask if you could provide us with your product serial number through a private message for reference?
Providing detailed device specifications (MB/CPU/GPU/PSU, etc.) and the respective driver versions, OS version, and BIOS version will help us analyze the issue more effectively.
