01-14-2026 01:40 AM
Hi everyone,
I’m looking for some advice or to see if others are experiencing this with the new 2025 Zephyrus G16. I’ve encountered a persistent and very annoying coil whine issue that seems specifically tied to the battery charging state.
The Issue: Whenever my battery hits the charging limit (I use G-Helper to cap it at 80%), the laptop begins emitting a high-pitched electrical buzzing/coil whine.
The Specifics:
The Trigger: It only starts once the battery reaches the 80% threshold. If it's actively charging (e.g., at 50%), it's silent.
The Problem: The noise persists even when the laptop is completely shut down, as long as the power cable is plugged in.
The Only Fix: Unplugging the AC adapter or changing the charge limit to 100% (which I don't want to do for battery health reasons).
What I’ve Tried:
Switching between the slim power port and USB-C charging (whine persists on both).
Updating BIOS to the latest version.
Disabling CPU Boost in G-Helper (helps slightly when the laptop is ON, but does nothing when it's OFF).
It seems like the power delivery system is "pulsing" or struggling to maintain the cap, creating audible resonance.
My Questions:
Is anyone else with the 2025 G16 hearing this at their battery cap?
Are there any BIOS settings (like ErP or C-States) that have successfully silenced this for you without sacrificing battery health?
Should I consider this a "normal" characteristic of this year's VRMs, or is this grounds for an RMA?
I really love the machine, but I need the coil whine off at all times, especially when I'm trying to sleep and the laptop is "off" on my desk.
Thanks in advance for any help!
01-14-2026 10:11 PM
@japsoares22
It is recommend that you first uninstall G-Helper and reinstall ASUS Armoury Crate to manage battery and power settings, in order to rule out any issues caused by third-party software.
Also, please ensure you are using the original ASUS charger and plug the power directly into a wall outlet (avoiding extension cords) to eliminate any impact from unstable power supply.
Afterward, please observe whether the issue still persists.
01-15-2026 06:14 AM
I have already tried both steps:
01-18-2026 11:24 PM
@japsoares22
Please kindly provide the following information to assist us:
We apologize for any inconvenience caused.
01-20-2026 05:52 AM
Hi Falcon2_ROG,
Thank you for your assistance. Here are the requested details from my system:
Model Name: GU605C
BIOS Version: 310
PD_FW Firmware: 0003
MyASUS Version: 4.0.58.0
OS Build: Windows 11 Home (22631)
here is the video: the sound is a high pitch noise coming from around the middle of the keyboard. g/h keys;
01-20-2026 05:57 AM
Sorry i misstyped the model name - its GU605CX. the 5090 model. thanks
01-21-2026 10:05 PM
@japsoares22
I will forward this to the technical team for verification.
Also, I’ve sent you a message, please provide your product serial number via that message.
01-22-2026 02:08 AM
hello, ive sent the serial number, thanks for the availability and help. looking foward to hear from you again
01-30-2026 12:24 PM
hello, havent found a fix yet. they told me to send it in for repair
