Setting up a laptop for network and battery operation
tomashined
Hello. Please tell me how to configure the laptop in Armoury Crate and MyASUS to enable Silent mode in case of battery operation and to enable Performance in case of network operation. And also turn on Turbo mode in case of launching any game.
1 ACCEPTED SOLUTION
Accepted Solutions
Anbby_ROG
Customer Service Agent
Hi @tomashined ,
Unfortunately, due to the current design, all performance modes require manual adjustment and configuration based on user preferences and usage scenarios.There is no automatic mode setting based on behavior.
I will forward your feedback to the relevant team for evaluation. We hope to provide users with a better experience in the future. Thank you for your valuable feedback and understanding.
Anbby_ROG
Hi @tomashined ,
Could you please confirm your laptop model for me?
Also, I would like to confirm if you want Armoury Crate and MyASUS to automatically switch the performance modes when removing the power source, using the network, and playing games?
These modes are designed to adapt to different usage scenarios, but they still require manual configuration from the user to adjust the performance modes. Additionally, I would like to remind that the "Turbo" mode should be used when the laptop is connected to the power adapter.
Thank you for your understanding.
Hi, @Anbby_ROG
Laptop is ROG Zephyrus Duo 16 (2023) GX650PY-XS97
I want that when the laptop is on battery, the Silent mode is turned on automatically. When the laptop is plugged in, then - Performance. And if the launch of any game is detected, then automatically turn on Turbo mode, and turn it off if the game is turned off.
Anbby_ROG
Hi @tomashined ,
