Screen greyed out and using small color space
nathanj
Asus ROG Zephyrus Duo 16 (2024) GX650PY-XS97
Hi I am having trouble getting my native monitor on my laptop to display colors correctly. My main monitor is greyed out and cannot use any of the color profiles correctly. (Fn + V) Cinema, Eye Care, Vivid, and Default all have zero changes. The native desktop background now is full of artifacts in the shadows.
This all happened when a friend using my laptop accidentally hit Fn + V a few weeks ago, and the native main monitor ende dup in a red+green barely decipherable color space that was only remedied when I changed the GPU profile to Ultimate in Armoury Crate. That is not the only usable GPU profile, and it still doesn't look great. Any integrated graphics settings (Standard, Eco, Optimized) will revert back to the green-red color space that is unusable.
Secondary lower touch monitor displays just fine. Externally connected 3rd monitor displays just fine.
There seemed to have been a solution here about a year ago stating to upgrade to  ASUS System Control Interface v3 3.1.31 but my system is already on 3.1.40, and won't revert on download. I have no option to rollback this driver in the panel.
Looking for help to fix my $4k laptop that breaks majorly every few months. Thanks
Anbby_ROG
Customer Service Agent
May I ask if you have tried using DDU to completely remove the AMD display driver, and then reinstall the ASUS-verified AMD graphics driver version V31.0.14038.8002 to see if the issue improves? Thank you.
Due to the regional holidays, my responses may be slightly delayed.
Thank you in advance for your patience and understanding 🙂
