RGB led issues a single color isn't working
VictorLeccese
Three day ago before updating armoury crate, my keyboard rgb backlight was working properly, after some update, the red color stopped working, now only blue and green lights light up, I have a tuf f15 (tuf507VU), tried uninstalling and reinstalling keyboard drivers, armoury crate, installing other apps for rgb control like openRGB and GHelper, but none worked, at windows 11 personalization config for dynamic lighting, the keyboard isn't even recognized anymore, it only shows the message "No Dynamic Lighting - compatible devices detected", I've also tried to find some dll's like shown in other posts to rename and try to make it work once again, but nothing worked at all.
Falcon2_ROG
Customer Service Agent
@VictorLeccese
Based on the situation you described, we recommend that you completely uninstall Armoury Crate and ASUS System Control Interface v3. Then, reinstall Armoury Crate and ASUS System Control Interface v3 and check if the issue is resolved. If the problem persists, to rule out any system-related faults, we suggest backing up your data and restoring the system for further confirmation. We apologize for any inconvenience caused.
