not charging battery while power AC on
alainroger
I have a 18" laptop ROG Strix G834JZ and I was wondering if there is a way to avoid to use the battery while laptop is plugged to power AC ?
so it will save the battery.
thx
Anbby_ROG
Customer Service Agent
Hi @alainroger ,
Please enable the Battery Health Charging feature in MyASUS, which limits the battery charge to 80% and helps to prolong the battery lifespan.
Once the Battery Health Charging feature is enabled, if you continuously keep the AC adapter connected, the system will intelligently adjust the battery charging threshold to protect the battery. If you need to immediately charge the battery to 80%, you can unplug and reconnect the AC adapter to meet your requirement. This information is provided for your reference. Thank you.
