GPU stuck in extreme power saving mode
SereneAngler
A lot of Discussions on this topic with no result and topic closed for some reason lol.
I have updated all drivers. Uninstalled armory crate, installed g-helper, restarted my pc 20 times, unplugged, plugged power supply, changed GPU modes from eco to standard to Ultimate. Nothing works, and it happened after Windows update I did yesterday.
Just got my laptop from warranty service where they replaced motherboard/GPU because of some error in GPU...
Should have just bought, 4090 and made a box...
ROG Strix SCAR G17
Anbby_ROG
Customer Service Agent
You mentioned that all drivers have been updated — may I ask if you've tested the ASUS-validated graphics drivers specifically?
Since the issue started after a Windows update, we recommend rolling back the update to check if that helps improve the situation.
If the problem still persists, kindly send us the following information via private message so we can coordinate with the local service team to further investigate your case. Thank you!
  • Name:
  • Phone:
  • Product Serial Number:
  • RMA Number:
To speed up issue identification, please provide the product model, BIOS, and driver versions, along with the troubleshooting steps you've already tried to avoid redundant checks.
⚠️ DM are for collecting personal information only. For technical assistance, please post your issue in the discussion thread so everyone can help and share insights! Thank you for your understanding! 🙂
