GPU Looks Like Its Running on Extreme Power Saving mode (IN ULTIMATE MODE)
Qusuto
I usually use my laptop's fans on manual settings because of the overheating problem on the Zephyrus G14 2022. When I first checked the Armoury Crate main page, I immediately noticed that my CPU was running at a high 90s with only 10% usage. When I switched it to Windows mode, the temperature dropped to the low 70s, but my GPU still seemed to be in extreme power saving mode. Moreover GPU mode is on ultimate.I've tried the following:
1) Reinstalling Armoury Crate
2) Disabling and re-enabling the GPU on Device Manager
3) Restarting my laptop too many times
These unfortunately didin't solve the issue. I'd like to know if there's a problem with my device or if it's a software issue. Please let me know if you have any suggestions.
1 ACCEPTED SOLUTION
Accepted Solutions
Anbby_ROG
Customer Service Agent
Hi @Qusuto ,
Due to the need for your personal information.
I have sent you a message, please check✉. Thank you
To speed up issue identification, please provide the product model, BIOS, and driver versions, along with the troubleshooting steps you've already tried to avoid redundant checks.
⚠️ DM are for collecting personal information only. For technical assistance, please post your issue in the discussion thread so everyone can help and share insights! Thank you for your understanding! 🙂
5 REPLIES 5
Qusuto
Also in task manager I can see my GPU is running. And I suppose its not in extreme power saving
Anbby_ROG
ould you please try removing ASUS System Control Interface v3, uninstalling Armoury Crate using the uninstall tool, and then reinstalling ASUS System Control Interface v3 and Armoury Crate to see if there is any improvement?
Additionally, I would like to confirm the current versions of your BIOS and graphics driver. Thank you!
how to remove  ASUS System Control Interface v3
I removed ASUS System Control Interface v3 on device manager and reinstalled armoury crate using your links but problem still exists 😞
Anbby_ROG
Hi @Qusuto ,
