05-19-2025 05:33 AM
Hi everyone,
I’m experiencing a serious issue on my ASUS ROG Strix Scar 16 (G634JZ, 2023 model).
The keyboard has completely stopped working — no key input, no RGB backlighting, no response from the front and rear LED bars, and the ROG logo light is also off. The only part that still works is the power button, which is part of the keyboard module.
This is what I’ve tried so far:
The issue appeared once, resolved itself for a few days, and then came back permanently. No software or driver fixes helped. From what I can tell — and after deep inspection — this seems to be a hardware-level issue either in the keyboard module itself or the embedded controller on the motherboard.
This device cost me over $3,500 and is just around 3 years old with very light use. A total failure of keyboard and lighting functions is simply unacceptable at this level. I’ve seen others here report similar cases — which suggests this could be a recurring hardware defect.
I’m sharing my case in detail in case it helps others, and I would really appreciate feedback or escalation from ASUS on this.
05-23-2025 02:13 AM
Based on your description, as we are unable to verify each user's usage scenario or the actual condition of the device, we recommend bringing the device to a local service center for further inspection to help clarify the issue. Thank you for your understanding.
