Battery life problem on Zephyrus g15 2021
Kalpak_Nirale
i dont understand why but my zephyrus g15 2021 with 3060 and r9 5900hs but i am getting only 2:30 hrs, i think i should be getting much more than that maybe 6hrs i hope, i have checked the battery life its operating at 98-96% battery health. GPU was on power saving, no activity other than youtube with 1080p video, keyboard light turned off.
PLEASE help if anyone has a solution to the problem
@Jiaszzz_ROG@Aureliannn_ROG@Bobby_ROG@Anbby_ROG, @
9 REPLIES 9
Anbby_ROG
Customer Service Agent
Hi @Kalpak_Nirale ,
Regarding battery usage, due to the chemical properties of lithium ions in lithium batteries, the battery capacity will gradually decline over time, usage environment, and usage habits.
Besides the aging effects, the discharge speed of the battery is also determined by the applications running on your device and the system power management settings.
For instance, running software that requires extensive computation, such as graphic design software, games, and video playback, will accelerate battery consumption. Additionally, some applications might continue to operate in the background, consuming system performance and battery power. Please refer to this link for more information. Thank you.
To speed up issue identification, please provide the product model, BIOS, and driver versions, along with the troubleshooting steps you've already tried to avoid redundant checks.
⚠️ DM are for collecting personal information only. For technical assistance, please post your issue in the discussion thread so everyone can help and share insights! Thank you for your understanding! 🙂
i dont know sir, it was fine before a few months. The only task i was running was youtube the playback should be more than 2:30hrs. on windows 10 not long ago i was getting close to 5-6hrs of battery life,  i had switched to windows 11 a few months back and after a week or so i noticed the battery problem.
Is it a problem with windows 11 drivers??
Maybe it's related to the high cpu usage of Armoury Crate when laptop is in Eco Mode. This issue has something to be with NVIDIA drivers and Armoury Crate, not fixed yet.
any idea when new drivers would come out ?
Anbby_ROG
Hi @Kalpak_Nirale ,
You mentioned that the battery life on Windows 10 is 5-6 hours. Could you confirm if this is while watching videos? Have you tried reinstalling Windows 10 to see if the issue improves?
Additionally, have you checked which applications are consuming most of the battery to further clarify the battery usage? Thank you.
Yes it was while watching YouTube video at 1440p
Also no I haven't tried getting back to windows 10. Windows 11 has a few feature that I appreciate and don't want to switch back.
I will repeat no other tasks were being performed. And cpu usage was hovering around 7-12% with ram usage at 45% if that helps
Anbby_ROG
Hi @Kalpak_Nirale ,
Windows 10 and Windows 11 differ in many aspects of system design, which can affect the standby time of a device when in battery mode. Especially when watching videos, the battery can drain quickly. We recommend testing the battery life in a normal standby state. The above information is provided for your reference.
humanhealer786
Hello sir,even my Asus ROG laptop shows similar problem like when I click hibernate mode,then sometimes it can restart,but sometimes,it simply won't charge neither would it restart by pressing power button. I have to long press power button multiple times to restart my laptop. Even the same problem occured once when I switch off laptop by shut down option and put the laptop to charge overnight and in morning,it simply won,t charge and it won't even start unless I long press power button. Its a new laptop sir and I am worried..What to do ?
Thank you in advance,You are doing a great job out there
Contact - mrsadikurrahman@gmail.com
Anbby_ROG
Hi @humanhealer786 ,
Since your issue does not align with this discussion topic, to ensure that your problem can be seen and discussed by other users, we suggest that you create a new discussion. Please include the product model, BIOS version, and detailed usage scenario. This will help everyone to better understand and clarify the issue. Thank you.
