Battery Health Charging for G750JM?
MLL01
Good afternoon!
I'm trying to find a definitive answer as to whether or not the model G750JM is compatible with the Asus Battery Health Charging app, and/or if battery health charging is supported through the MyAsus app on that model of laptop.
So far, I have been unable to find any battery-settings within MyAsus, and I can't find any download links for the standalone app.
Online information regarding this question is highly contradictory, and I'm hoping for some clarity on the subject.
As a potential follow-up question: Assuming the G750JM is in fact incompatible with the above apps, are there alternative methods for capping battery-charging below 100 percent?
Thanks, in advance, for the help!
1 ACCEPTED SOLUTION
Accepted Solutions
Falcon2_ROG
Customer Service Agent
@MLL01
The following should be the feature you need:
https://www.asus.com/support/faq/1032726/
Since your product is an earlier model, it is normal that the related feature does not appear in the MyASUS application.
https://www.asus.com/support/faq/1045716/
Question 4: Why can I only see the partial features in the MyASUS app?
Answer 4: When you download MyASUS from the Microsoft Store, you may only see partial functionalities, lacking features such as system diagnostics, software updates, and device settings. It is because your product is not equipped with ASUS System Control Interface driver or the driver version does not support the full functionality of MyASUS. For more information, please refer to this article.
Falcon2_ROG
@MLL01
