11-25-2024 09:50 PM
Hey all,
I followed this article (https://rog.asus.com/support/faq/1047786/) to setup WPS button to turn on/off LED lights on my GT6. I need this to allow my kids to turn LED without asking me to do that via mobile application.
But instead of turning lights on/off this button is changing style of LED lights/Aura RGB (static > breathing > wave > etc.). Do you experience the same?
Also, one another strange thing - turning LED lights on/off from mobile ASUS Router app doesn't work from first attempt. For example, to turn off LED lights I need to:
This is super inconvenient as I have to do that for each GT6 node...
I've contacted support, but all I've got back was a message that such problem was not received/registered and recommendation to hope that it will be fixed in one of next firmware releases.
ty
11-26-2024 12:55 AM
Small update - it seems that turning LED lights on/off doesn't work only on secondary node. I can turn LED lights on/off and change lights style on primary node (holding for 3 seconds to turn LED on/off, and 1 second - to change LED style). Unfortunately secondary node is the one that sits in kids room...
Sounds like configuration sync bug.
12-04-2024 07:13 PM
Hi @typhoon2k ,
Regarding the WPS button issue you're experiencing, we recommend trying the following steps:
If the above methods do not resolve your issue, we recommend that you send your router to the nearest authorized service center for further inspection and repair. Thank you.
12-04-2024 10:55 PM
Hey @Aureliannn_ROG ,
thanks for your hints!
I'm on the latest version of firmware already and tried device restarts/reset. Unfortunately that didn't help.
I've also contacted support and their reply was that it is how it works (that this is a feature, not a bug). I can speculate here that it was done for some WPS security reasons OR it's just because WPS button configuration is not sync'ed to other nodes in mesh.
I've asked to submit feature request, perhaps it will be implemented one day.
Meanwhile some folks on this forum proposed to try to change WPS button configuration on that node before joining mesh. It is a bit inconvenient, but I'll give it a try.
ty
