RT-AX89X going out of memory every 10 minutes (asd process?)
shievan
Hello, my router froze up overnight, so I rebooted it, and ever since the logs are showing that it is going OOM about every 10 minutes. First it starts spamming:
May 17 10:44:26 kernel: [ 5872.720019] wlan: [0:E:QDF] NBUF alloc failed 12107B @ dp_get_ppdu_desc:3430
May 17 10:44:26 kernel: [ 5873.235497] wlan: [0:E:QDF] NBUF alloc failed 12107B @ dp_get_ppdu_desc:3430
May 17 10:44:27 kernel: [ 5873.747543] wlan: [0:E:QDF] NBUF alloc failed 12107B @ dp_get_ppdu_desc:3430
May 17 10:44:27 kernel: [ 5874.259510] wlan: [0:E:QDF] NBUF alloc failed 12107B @ dp_get_ppdu_desc:3430
May 17 10:44:28 kernel: [ 5874.771556] wlan: [0:E:QDF] NBUF alloc failed 12107B @ dp_get_ppdu_desc:3430
Then it looks like a high memory killer kicks in and kills a process called asd:
May 17 10:44:30 kernel: [ 5876.819570] wlan: [0:E:QDF] NBUF alloc failed 12107B @ dp_get_ppdu_desc:3430
May 17 10:44:31 kernel: [ 5877.219109] mcsd invoked oom-killer: gfp_mask=0x24004c0, order=2, oom_score_adj=0
May 17 10:44:31 kernel: [ 5877.219144] CPU: 2 PID: 20987 Comm: mcsd Tainted: P                4.4.60 #1
May 17 10:44:31 kernel: [ 5877.225567] Hardware name: Generic DT based system
May 17 10:44:31 kernel: [ 5877.232709] [<8022001c>] (unwind_backtrace) from [<8021c8c4>] (show_stack+0x10/0x14)
May 17 10:44:31 kernel: [ 5877.237296] [<8021c8c4>] (show_stack) from [<803b8590>] (dump_stack+0x78/0x98)
May 17 10:44:31 kernel: [ 5877.245195] [<803b8590>] (dump_stack) from [<802a7d38>] (dump_header+0x44/0x164)
May 17 10:44:31 kernel: [ 5877.252241] [<802a7d38>] (dump_header) from [<802a825c>] (oom_kill_process+0xcc/0x448)
May 17 10:44:31 kernel: [ 5877.259775] [<802a825c>] (oom_kill_process) from [<802a8924>] (out_of_memory+0x2e4/0x354)
May 17 10:44:31 kernel: [ 5877.267520] [<802a8924>] (out_of_memory) from [<802ac4d4>] (__alloc_pages_nodemask+0x67c/0x738)
May 17 10:44:31 kernel: [ 5877.275752] [<802ac4d4>] (__alloc_pages_nodemask) from [<802ac5a0>] (__get_free_pages+0x10/0x24)
May 17 10:44:31 kernel: [ 5877.284275] [<802ac5a0>] (__get_free_pages) from [<80225d70>] (pgd_alloc+0x18/0x144)
May 17 10:44:31 kernel: [ 5877.293301] [<80225d70>] (pgd_alloc) from [<80228478>] (mm_init+0xcc/0x138)
May 17 10:44:31 kernel: [ 5877.301027] [<80228478>] (mm_init) from [<802e1854>] (do_execveat_common+0x284/0x5f4)
May 17 10:44:31 kernel: [ 5877.307697] [<802e1854>] (do_execveat_common) from [<802e1bf0>] (do_execve+0x2c/0x34)
May 17 10:44:31 kernel: [ 5877.315695] [<802e1bf0>] (do_execve) from [<80209bc0>] (ret_fast_syscall+0x0/0x34)
May 17 10:44:31 kernel: [ 5877.323544] Mem-Info:
May 17 10:44:31 kernel: [ 5877.331211] active_anon:161197 inactive_anon:1485 isolated_anon:0
May 17 10:44:31 kernel: [ 5877.331211]  active_file:90 inactive_file:127 isolated_file:7
May 17 10:44:31 kernel: [ 5877.331211]  unevictable:0 dirty:52 writeback:1 unstable:0
May 17 10:44:31 kernel: [ 5877.331211]  slab_reclaimable:875 slab_unreclaimable:31662
May 17 10:44:31 kernel: [ 5877.331211]  mapped:220 shmem:1513 pagetables:602 bounce:0
May 17 10:44:31 kernel: [ 5877.331211]  free:4778 free_pcp:4 free_cma:0
May 17 10:44:31 kernel: [ 5877.331557] wlan: [0:E:QDF] NBUF alloc failed 12107B @ dp_get_ppdu_desc:3430
May 17 10:44:31 kernel: [ 5877.365795] Normal free:18404kB min:3752kB low:4688kB high:5628kB active_anon:644788kB inactive_anon:5940kB active_file:648kB inactive_file:916kB unevictable:0kB isolated(anon):0kB isolated(file):128kB present:898048kB managed:881836kB mlocked:0kB dirty:208kB writeback:4kB mapped:1176kB shmem:6052kB slab_reclaimable:3500kB slab_unreclaimable:126648kB kernel_stack:1432kB pagetables:2408kB unstable:0kB bounce:0kB free_pcp:544kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_
May 17 10:44:31 kernel: [ 5877.395533] lowmem_reserve[]: 0 0 0
May 17 10:44:31 kernel: [ 5877.421214] Normal: 4597*4kB (U) 0*8kB 0*16kB 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 18388kB
May 17 10:44:31 kernel: [ 5877.431371] 2010 total pagecache pages
May 17 10:44:31 kernel: [ 5877.432161] 0 pages in swap cache
May 17 10:44:31 kernel: [ 5877.435905] Swap cache stats: add 0, delete 0, find 0/0
May 17 10:44:31 kernel: [ 5877.439280] Free swap  = 0kB
May 17 10:44:31 kernel: [ 5877.444308] Total swap = 0kB
May 17 10:44:31 kernel: [ 5877.447454] 224512 pages RAM
May 17 10:44:31 kernel: [ 5877.450298] 0 pages HighMem/MovableOnly
May 17 10:44:31 kernel: [ 5877.453163] 4053 pages reserved
May 17 10:44:31 kernel: [ 5877.457046] Out of memory: Kill process 9710 (asd) score 684 or sacrifice child
May 17 10:44:31 kernel: [ 5877.459867] Killed process 9710 (asd) total-vm:625440kB, anon-rss:621348kB, file-rss:60kB
 Looking back at when the router locked up initially overnight, it seems like it tried to look for a firmware update automatically around 4am, (which is strange because I have auto updates turned off), then started spamming the 'NBUF alloc failed' message:
May 17 03:48:01 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7616)]do webs_update
May 17 03:48:05 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7634)]retrieve firmware information
May 17 03:48:05 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7649)]fimrware update check first time
May 17 03:48:05 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7682)]no need to upgrade firmware
May 17 03:48:35 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7616)]do webs_update
May 17 03:48:35 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7634)]retrieve firmware information
May 17 03:48:35 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7654)]fimrware update check once
May 17 03:49:05 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7616)]do webs_update
May 17 03:49:05 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7634)]retrieve firmware information
May 17 03:49:05 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7654)]fimrware update check once
May 17 03:49:35 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7616)]do webs_update
May 17 03:49:35 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7634)]retrieve firmware information
May 17 03:49:35 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7649)]fimrware update check first time
May 17 03:49:35 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7682)]no need to upgrade firmware
May 17 03:57:55 kernel: [1382843.922889] wlan: [0:E:QDF] NBUF alloc failed 12107B @ dp_get_ppdu_desc:3430
May 17 03:57:55 kernel: [1382844.435933] wlan: [0:E:QDF] NBUF alloc failed 12107B @ dp_get_ppdu_desc:3430
May 17 03:57:56 kernel: [1382845.012988] wlan: [0:E:QDF] NBUF alloc failed 12107B @ dp_get_ppdu_desc:3430
May 17 03:57:56 kernel: [1382845.525014] wlan: [0:E:QDF] NBUF alloc failed 12107B @ dp_get_ppdu_desc:3430
 Any help greatly appreciated!
235 REPLIES 235
privacypiracy
same problem here
hatamotochi
May 17 11:03:53 kernel: [ 1321.761749] wlan: [0:E:QDF] NBUF alloc failed 12107B @ dp_get_ppdu_desc:3430
May 17 11:03:58 kernel: [ 1326.315936] Out of memory: Kill process 14216 (asd) score 693 or sacrifice child
May 17 11:14:30 kernel: [ 1958.086729] wlan: [0:E:QDF] NBUF alloc failed 12107B @ dp_get_ppdu_desc:3430
May 17 11:14:32 kernel: [ 1959.823091] Out of memory: Kill process 27009 (asd) score 695 or sacrifice child
May 17 11:25:06 kernel: [ 2594.104391] wlan: [0:E:QDF] NBUF alloc failed 12107B @ dp_get_ppdu_desc:3430
May 17 11:25:06 kernel: [ 2594.850197] Out of memory: Kill process 6549 (asd) score 696 or sacrifice child
May 17 11:35:23 kernel: [ 3211.177631] wlan: [0:E:QDF] NBUF alloc failed 12107B @ dp_get_ppdu_desc:3430
May 17 11:35:47 kernel: [ 3235.359531] Out of memory: Kill process 18905 (asd) score 699 or sacrifice child
Filtered out some spam in the logs and duplicate prints for alloc fail and it's obvious some timer is causing this every 10 minutes.
Same exact issue here! Started last night...
I'm within the return window debating if I should return. Anyone contact ASUS?
ealagna
I opened a support chat and they suggested I downgrade the firmware. Trying that now.
I've tried downgrading to the previous firmware, it didn't seem to change anything 😞
MorsCanis
Downgraded firmware to previous version and the router has not locked up in the last 40 mins. This might be a server side issue on ASUS for the firmware check.
PNW-Bob
Did you do a manual upload of the prior firmware version?
Looks like the last firmware update was on 5/12 (5 days ago).
Current Version : 3.0.0.4.386_47468-g73fe1fe
Yeah, I grabbed the 3.0.0.4.386.47191 version from the support page. Then I manually uploaded it.
It's not saying the firmware was updated 5 days ago, that's the anti-virus/site blocking signature file update. Your firmware version is from Oct 2022.
diebar
Same happening here. Started this morning. Seems my router was auto updated even though I have automatic updates disabled.
Are your cases the same?
