RT-AX89X going out of memory every 10 minutes (asd process?)
shievan
Hello, my router froze up overnight, so I rebooted it, and ever since the logs are showing that it is going OOM about every 10 minutes. First it starts spamming:
May 17 10:44:26 kernel: [ 5872.720019] wlan: [0:E:QDF] NBUF alloc failed 12107B @ dp_get_ppdu_desc:3430
May 17 10:44:26 kernel: [ 5873.235497] wlan: [0:E:QDF] NBUF alloc failed 12107B @ dp_get_ppdu_desc:3430
May 17 10:44:27 kernel: [ 5873.747543] wlan: [0:E:QDF] NBUF alloc failed 12107B @ dp_get_ppdu_desc:3430
May 17 10:44:27 kernel: [ 5874.259510] wlan: [0:E:QDF] NBUF alloc failed 12107B @ dp_get_ppdu_desc:3430
May 17 10:44:28 kernel: [ 5874.771556] wlan: [0:E:QDF] NBUF alloc failed 12107B @ dp_get_ppdu_desc:3430
Then it looks like a high memory killer kicks in and kills a process called asd:
May 17 10:44:30 kernel: [ 5876.819570] wlan: [0:E:QDF] NBUF alloc failed 12107B @ dp_get_ppdu_desc:3430
May 17 10:44:31 kernel: [ 5877.219109] mcsd invoked oom-killer: gfp_mask=0x24004c0, order=2, oom_score_adj=0
May 17 10:44:31 kernel: [ 5877.219144] CPU: 2 PID: 20987 Comm: mcsd Tainted: P                4.4.60 #1
May 17 10:44:31 kernel: [ 5877.225567] Hardware name: Generic DT based system
May 17 10:44:31 kernel: [ 5877.232709] [<8022001c>] (unwind_backtrace) from [<8021c8c4>] (show_stack+0x10/0x14)
May 17 10:44:31 kernel: [ 5877.237296] [<8021c8c4>] (show_stack) from [<803b8590>] (dump_stack+0x78/0x98)
May 17 10:44:31 kernel: [ 5877.245195] [<803b8590>] (dump_stack) from [<802a7d38>] (dump_header+0x44/0x164)
May 17 10:44:31 kernel: [ 5877.252241] [<802a7d38>] (dump_header) from [<802a825c>] (oom_kill_process+0xcc/0x448)
May 17 10:44:31 kernel: [ 5877.259775] [<802a825c>] (oom_kill_process) from [<802a8924>] (out_of_memory+0x2e4/0x354)
May 17 10:44:31 kernel: [ 5877.267520] [<802a8924>] (out_of_memory) from [<802ac4d4>] (__alloc_pages_nodemask+0x67c/0x738)
May 17 10:44:31 kernel: [ 5877.275752] [<802ac4d4>] (__alloc_pages_nodemask) from [<802ac5a0>] (__get_free_pages+0x10/0x24)
May 17 10:44:31 kernel: [ 5877.284275] [<802ac5a0>] (__get_free_pages) from [<80225d70>] (pgd_alloc+0x18/0x144)
May 17 10:44:31 kernel: [ 5877.293301] [<80225d70>] (pgd_alloc) from [<80228478>] (mm_init+0xcc/0x138)
May 17 10:44:31 kernel: [ 5877.301027] [<80228478>] (mm_init) from [<802e1854>] (do_execveat_common+0x284/0x5f4)
May 17 10:44:31 kernel: [ 5877.307697] [<802e1854>] (do_execveat_common) from [<802e1bf0>] (do_execve+0x2c/0x34)
May 17 10:44:31 kernel: [ 5877.315695] [<802e1bf0>] (do_execve) from [<80209bc0>] (ret_fast_syscall+0x0/0x34)
May 17 10:44:31 kernel: [ 5877.323544] Mem-Info:
May 17 10:44:31 kernel: [ 5877.331211] active_anon:161197 inactive_anon:1485 isolated_anon:0
May 17 10:44:31 kernel: [ 5877.331211]  active_file:90 inactive_file:127 isolated_file:7
May 17 10:44:31 kernel: [ 5877.331211]  unevictable:0 dirty:52 writeback:1 unstable:0
May 17 10:44:31 kernel: [ 5877.331211]  slab_reclaimable:875 slab_unreclaimable:31662
May 17 10:44:31 kernel: [ 5877.331211]  mapped:220 shmem:1513 pagetables:602 bounce:0
May 17 10:44:31 kernel: [ 5877.331211]  free:4778 free_pcp:4 free_cma:0
May 17 10:44:31 kernel: [ 5877.331557] wlan: [0:E:QDF] NBUF alloc failed 12107B @ dp_get_ppdu_desc:3430
May 17 10:44:31 kernel: [ 5877.365795] Normal free:18404kB min:3752kB low:4688kB high:5628kB active_anon:644788kB inactive_anon:5940kB active_file:648kB inactive_file:916kB unevictable:0kB isolated(anon):0kB isolated(file):128kB present:898048kB managed:881836kB mlocked:0kB dirty:208kB writeback:4kB mapped:1176kB shmem:6052kB slab_reclaimable:3500kB slab_unreclaimable:126648kB kernel_stack:1432kB pagetables:2408kB unstable:0kB bounce:0kB free_pcp:544kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_
May 17 10:44:31 kernel: [ 5877.395533] lowmem_reserve[]: 0 0 0
May 17 10:44:31 kernel: [ 5877.421214] Normal: 4597*4kB (U) 0*8kB 0*16kB 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 18388kB
May 17 10:44:31 kernel: [ 5877.431371] 2010 total pagecache pages
May 17 10:44:31 kernel: [ 5877.432161] 0 pages in swap cache
May 17 10:44:31 kernel: [ 5877.435905] Swap cache stats: add 0, delete 0, find 0/0
May 17 10:44:31 kernel: [ 5877.439280] Free swap  = 0kB
May 17 10:44:31 kernel: [ 5877.444308] Total swap = 0kB
May 17 10:44:31 kernel: [ 5877.447454] 224512 pages RAM
May 17 10:44:31 kernel: [ 5877.450298] 0 pages HighMem/MovableOnly
May 17 10:44:31 kernel: [ 5877.453163] 4053 pages reserved
May 17 10:44:31 kernel: [ 5877.457046] Out of memory: Kill process 9710 (asd) score 684 or sacrifice child
May 17 10:44:31 kernel: [ 5877.459867] Killed process 9710 (asd) total-vm:625440kB, anon-rss:621348kB, file-rss:60kB
 Looking back at when the router locked up initially overnight, it seems like it tried to look for a firmware update automatically around 4am, (which is strange because I have auto updates turned off), then started spamming the 'NBUF alloc failed' message:
May 17 03:48:01 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7616)]do webs_update
May 17 03:48:05 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7634)]retrieve firmware information
May 17 03:48:05 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7649)]fimrware update check first time
May 17 03:48:05 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7682)]no need to upgrade firmware
May 17 03:48:35 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7616)]do webs_update
May 17 03:48:35 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7634)]retrieve firmware information
May 17 03:48:35 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7654)]fimrware update check once
May 17 03:49:05 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7616)]do webs_update
May 17 03:49:05 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7634)]retrieve firmware information
May 17 03:49:05 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7654)]fimrware update check once
May 17 03:49:35 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7616)]do webs_update
May 17 03:49:35 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7634)]retrieve firmware information
May 17 03:49:35 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7649)]fimrware update check first time
May 17 03:49:35 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7682)]no need to upgrade firmware
May 17 03:57:55 kernel: [1382843.922889] wlan: [0:E:QDF] NBUF alloc failed 12107B @ dp_get_ppdu_desc:3430
May 17 03:57:55 kernel: [1382844.435933] wlan: [0:E:QDF] NBUF alloc failed 12107B @ dp_get_ppdu_desc:3430
May 17 03:57:56 kernel: [1382845.012988] wlan: [0:E:QDF] NBUF alloc failed 12107B @ dp_get_ppdu_desc:3430
May 17 03:57:56 kernel: [1382845.525014] wlan: [0:E:QDF] NBUF alloc failed 12107B @ dp_get_ppdu_desc:3430
 Any help greatly appreciated!
235 REPLIES 235
Do you know, will this firmware work on the ax89x ?
Yes, that (beta) software is expressly for the AX89X.  If you are wondering because it has a U instead of an X, they devs have confirmed that is how all the firmwares for it are labeled.
nighter2016
Thx @palito007.  Mine is still working too.
LazyTitanNZ
Yesterday I installed the beta firmware, which got me going. But, after reading the messages about a new chknvram20230518 being updated/downloaded, I used the Revert option to install the firmware version 3.0.0.4.386_47468.
Using ssh I checked that /jffs/asd/chknvram20230518 was there, and it is.
The router has been stable for over 2 hours - fingers crossed it stays that way!
Apooku
For me, i had no chknvram20230518 file. What eventually fixed it was enabling the "AiProtection". I did this since someone mentioned that it is actually because of an "antivirus" not properly behaving due to that file. RAM usage is currently at a steady 60% and CPU usage is stable also. Previously there was one CPU used almost 100% all the time.
I have no idea why "AiProtection" would fix this, but tomorrow i plan to try and disable it again and see if it is still behaving ok. I guess it's "protecting" so much, even disabled, that it just kills the router so no one could ever get in 😄 even the owner.
Glad it is working and good to know there may be another workaround for folks.
To clarify, file that was the problem is chknvram20230516, not 18.  18 is the one they are saying would have downloaded after deleting 16.
tmaycsu
Decided to just wait for the tested/certified FW update they are probably frantically working on and using an older backup router that seems to be just fine till then.  It really sucks our $400 RT-AX89X's were all turned into paperweights without a faster response from Asus but the beta FW being offered tells me they are working on it.
JoeFox
Hey all,
I've got a similar issue on my RT-AC86U router. It's fine for a few hours, then the internet just drops out. A hard reset resolves the problem temporarily but only for a few hours. Pretty annoying.
I've read through al of the previous posts, enabled Telnet, etc., and checked to see whether the apparent offending file 'chknvram20230516' is present. The answer is that I don't seem to have it! In my /jffs/asd/ directory I have the following:
  • blockdnsip2022031601
  • blockfile2023051001
  • chknvram2021083002
  • monitorproc2022031401
  • version
So looks like my chknvram file is a couple of years old. Yet, I am having the same issue as you all report on here.  This suggests that the chknvram20230516 might not actually be the offending file.
The line in my system log that seems to repeat a lot before the drop out is as follows:
dnsmasq-dhcp[1783]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60s)
All pretty frustrating and annoying. I'd rather be proactive and try and fix this rather than put up with the regular trips to the router to perform  unplug/plug back in/wait routine, but I don't think there is anything in the previous posts that relate to my situation.
Does anyone else have an RT-AC86U? If so, are you experiencing issues? Have you resolved them, How did you resolve them?
Thanks,
JoeFox
I have a GT-AC2900 which is basically just a ROG rebranded RT-AC86U with a few minor changes.
Here are the steps I took to solve the problem:
1. Reboot router.
2. Quickly go and grab the latest firmware for your router on ASUS website before your router crashes.
3. Once you have the firmware downloaded, pull the WAN cable from your router and reboot it again.
4. Export your settings, then reset the router to factory defaults.
5. After it's reset, upload the firmware and let it install and reboot.
6. Import your settings, then plug your WAN cable back in, and you should be good to go.
Thanks @Rockstonicko
If I go to https://www.asus.com/supportonly/rt-ac86u/helpdesk_bios/?model2Name=RT-AC86U it appears the latest firmware is:
Version 3.0.0.4.386.51529
65.79 MB
2023/04/13
I've got that downloaded and have the .zip ready to go.
One problem I have is that I can't connect physically via a cable to my router - my laptop simply does not have a port for this type of thing.
Should I export settings from the router whilst it is connected to the internet (and I can connect to it via WiFi)?
Thanks,
JoeFox
