07-03-2023 09:44 AM - edited 07-03-2023 09:44 AM
Getting a new ROG Rapture GT-AX11000 Pro this week. I also have an 8 port TP-Link 2.5G Switch.
Is there any DOWNSIDE to just using only the 1 2.5G LAN port on the ROUTER connected to the switch and using the switch for my other 6 connections? The UPSIDE for me is much cleaner wiring. DO lose anything from doing that? Is using the physical router ports any "better"?
Thanks!
Solved! Go to Solution.
07-03-2023 09:56 AM
Thank you. That’s what I assumed but wasn’t sure if this router did anything “special” with the onboard ports 🙂
07-03-2023 09:53 AM
As long as you are happy for all the hosts on the switch to share that single 2.5G full duplex link to the WiFi and the Internet, there should be no downside of any significance. What you describe is a very normal network topology.
07-03-2023 09:56 AM
