03-26-2025 10:43 AM
Hi all, I am posting here because I have run out of solutions with my WiFi Mesh XT9 system. After less than one year, both the node and the main router are losing the setup and need to be reconfigured. A month ago, the node lost the setup and it had to be reset and reconfigured. Yesterday, the main router suddenly switched to setup mode asking for the name of the new network. The firmware was updated a month ago to the latest version on both devices (node and main router). I've been very happy with the Mesh system until these recent issues occurred. Is anyone having the same issue? Any ideas on potential solutions?
03-27-2025 04:21 AM
I've notice with the latest firmware update (388.24709) the node can only connect to the main router and not other nodes. And the wifi strength seems weaken.
03-30-2025 06:36 PM
Hi @DrZ @OldMan4Fun ,
Thank you very much for providing the detailed information.
To more effectively assist you in resolving the issue, we sincerely recommend that you create a post at the following link:
In your post, please describe the problem occurrence scenario in detail and provide relevant screenshots (if available).
Additionally, if you can submit relevant information through the system's built-in problem reporting function when the problem occurs, it will help our team analyze your problem more quickly.
Thank you for your cooperation.
