a month ago
So the GT-AXE16000 has a 2.5gb Wan port,Also i know you can use the 10gb port as your wan port,Do you lose any features or data priority options when not using the 2.5gb Wan port.only asking as the 2.5gb port specifically is labeled WAN port where as the 10GB port is not hope this makes sense thanks all
