12-10-2023 07:47 AM
Hello,
My GT-AX11000 does not load firmware restore. Firmware version is 3.0.0.4.384_6438-g901ff3c
When I powered on the machine and held down reset, the power button started blinking.
Then, I connected an Ethernet cable from the WAN PORT to my computer's Ethernet plug.
However, when I opened Device Discovery, nothing showed up. Firmware Restoration also didn't work.
(Sorry for the inconvenience, my computer is in Chinese.)
This is Device Discovery Tool
Translated:
Device, SSID, IP Address, Subnet Mask, Printer
Configure (C), Search (S), Exit (E)
Devices found: 0
This is Firmware Restoration
Translated:
Filename (F): , Browse (B)
Status:
No device found in restoration mode.
Upload (U), Close (C)
Does anyone know what's going on? Any help would be greatly appreciated.
Thanks,
therealmanzk101
12-10-2023 10:56 PM
I’m afraid the computer needs to connect to a LAN port, not WAN. Please follow this carefully:
12-10-2023 11:36 PM
Hi @ jzchen,
Thank you for your reply.
I tried the steps mentioned in the support document. However, connecting to any 4 of the router's LAN ports did not yield a successful result either. My computer still fails to detect the router at all, even when a wire is plugged into my computer's Ethernet port and LAN1 port, and recovery mode is enabled when the light flashes.
I left the IP settings as DHCP.
Thanks,
therealmanzk101
12-10-2023 11:45 PM
Please see the instructions again, in particular steps 2-1 to 2-9. They need to be followed for manual IP address assignment of the PC.
IP 192.168.50.10, or 192.168.1.10 (this I am not certain because one is old 192.168.1.10 and one is for newer routers 192.168.50.10.
Subnet 255.255.255.0
Please then continue with steps 3.x .
12-11-2023 12:04 AM
Because my router is a newer version, I set it to 192.168.50.x.
The settings are as follows:
Translation:
Automatically obtain IP address
. Use the IP address below:
IPv4 Address (I): 192.168.50.10
Subnet Mask (U): 255.255.255.0
Default Gateway (D): 192.168.50.1
However, Device Discovery still can't detect the device.
12-11-2023 12:32 AM
The instructions leave Default Gateway (D) empty/blank. If that doesn’t work please try the 192.168.1.10 .
(I have never used this utility. Does the router fail to boot?)
12-11-2023 12:37 AM
I've tried both 192.168.1.x and 192.168.50.x, and also leaving Default Gateway blank.
However, it still doesn't work.
12-11-2023 12:43 AM
I see. Does the router fail to boot up? When I read the instructions it is not clear if the restoration mode is available if it is functioning, or only can be enabled when it fails to boot.
When you press RESET and turn ON you wait until Power LED slowly blinks correct?
12-11-2023 04:42 AM
Please read “NOTE”
ASUS Firmware Restoration version 2.1.0.2
OS support: Windows XP/7/8/8.1/10
Firmware Restoration is used on an ASUS Wireless Router that failed during its firmware upgrading process. It uploads the firmware that you specify.
NOTE: This is not a firmware upgrade utility and cannot be used on a working ASUS Wireless Router. Normal firmware upgrades must be done through the web interface.
12-11-2023 10:39 PM
Hi @therealmanzk101 ,
based on your issue, may I ask what happened to your router so you neese to operate firmware restoration?
Firmware restoration can only be used in rescue mode.
If you want to update the firmware, we suggest downloading from official site.
Have you make sure that before uploading the file, please make sure that you already turn your router to the Rescue Mode.
Otherwise you can't use Firmware Restoration to do the firmware update.
Please refer to the following FAQ.
[Wireless Router] How to use Rescue Mode (Firmware Restoration)? | Official Support | ASUS Global
