6Ghz SSID blocked on MESH when using wired backhaul.
kerneldoug
I have a GT-BE98 Pro & a GT-AXE16000 in mesh mode, linked via hard wired 10G lan ports.  The 6Ghz SSID is blocked on the GT-AXE16000 with an _dwb on the SSID.   Any idea on how to free up the 6Ghz on the mesh node, since it's not actually be used for backhaul?
None of the WiFi ports on the BE98 Pro show as a backhaul, and both show correctly as "wired" and "great".  Preferences are set to wired, I've tried cycling the 6Ghz radio on and off, and it always adds the _dwb to the SSID on the mesh node. (the AXE-16000).
Hoping for a firmware fix will release the 6Ghz on the node, unless I'm doing something wrong.
kerneldoug
This has been resolved as of firmware 3.0.0.6.102_37031.
Aureliannn_ROG
Customer Service Agent
Hi @kerneldoug ,
Thank you very much for your feedback!
We are pleased firmware 3.0.0.6.102_37031 resolve the issue.
If you have any other questions or need further assistance, please feel free to ask.
We are here to assist you.
