ASUS PCE-AC88 Network Card and feedback in Logitech audio system
code2australia
Recent purchased and installed an ASUS PCE-AC88 Network Card on a Gigabyte Z97-HD3 (Rev 2.1) Motherboard. Almost immediately, there was feedback in my audio speaker systems (Logitech Z506 Surround Speakers 5.1 System), which were right near the computer.
I have since moved the speakers about 1.5 metres away from the computer, which helped. But on occasion, I still get some interference.
Has any heard of this before?
And, is there a solution (apart from moving the speakers further away, which I cannot really do) ?
Thanks in advance.
RedSector73
Level 12
On the ASUS PCE-AC88 Network Card, you could try another slot in the motherboard and check that the antenna plugs for Wi-Fi are done up, and try placing the antenna (transmitter/receiver) away from speakers or speaker cords.
Electromagnetic Interference is always fun, heights changes may help as well.
Thank you. I will try your suggestions.
