Temperature Source for Chassis Fan ignored by X670E-I, uses CPU Temp instead
808
I'm running a liquid loop, and would like my fan speeds to follow just the T. Sensor (temperature sensor header) reading, but the fan speeds still track the CPU / CPU Package temperature. Since the CPU Fan header has no option to follow anything but the CPU / CPU Package, I plugged my fans into the Chassis Fan header and left CPU Fan unpopulated with the CPU Fan RPM changed from Monitor to Ignore in UEFI.
Please advise.
On latest Feb 2024 UEFI Fan RPM, CPU, CPU Package, T. Sensor graphsFan RPM, CPU, CPU Package, T. Sensor graphs Image
1 ACCEPTED SOLUTION
Accepted Solutions
Silent_Scone
Super Moderator
Hi @808
Do you have Armoury Crate installed?
Have you navigated to the Monitor tab in the UEFI and selected the appropriate temperature source for Chassis headers?
Silent_Scone
Super Moderator
Hi @808
808
Thanks @Silent_Scone AC was installed and despite App Data reset (Windows 11) was overriding the UEFI settings with CPU temps. App crashes for me, ended up uninstalling it and restarting. With AC uninstalled fans are under control with the UEFI-based values
No worries 👍
FanXpert priority is a known issue on certain hardware configurations and has been reported (fix due soon).  Although it shouldn’t crash, perhaps check system stability.
