ROG Strix B650E-F Gaming Wifi no display signal white LED
SlapSHotMan19
This issue started trying to wake up my PC from sleep. It never came back. No recent updates made to anything. I updated the BIOS a couple months ago and everything was working fine until trying to wake it up today. When I turn it on, the monitors know to wake up, then go back to sleep with no signal and the PC never fully boots and the white VGA LED stays lit. All the fans and RGB turn on. It doesn't matter if I was using the display port on the GPU or the motherboard. Currently the GPU is completely removed and nothing changes when using the motherboard display port on its own. Just to be thorough, RAM has been reseated as well. Occasionally it will cycle through the other LEDs after sitting on white for awhile. Will go to red, amber, then back to white and stay there.
0 REPLIES 0
