04-15-2025 02:46 PM
I have a giant GPU so if I install it into the top slot (G5_1) tho lower slot (G5_2) is getting blocked and making it impossible to have Hyper M.2 card installed in there.
So I tried to install GPU into the second slot (G5_2) and have Hyper M.2 in the top slot (G5_1).
The problem is, when I check my SSD with HWiNFO my GEN 5 SSD only gets Maximum Link Width x2 instead x4 which drops the speed from 14.000mb to 7.000mb.
Can I fix it somehow? I tried so many options in BIOS and nothing works.
Does the top slot G5_1 only give 2 links? Why? Is it not suitable to have Hyper M.2 in the top slot?
04-15-2025 05:44 PM - edited 04-15-2025 05:46 PM
Hello Albertsp142
According to the manual, if you put the Hyper M.2 card in the G5_1 slot, it supports pcie 4.0 x4, so it wouldn't give you 14.000mb.
The only way to get pcie 5.0 speeds is with the hyper card in the G5_2 slot. The motherboard M.2 slots are all pcie 4.0.
