LAN Problems with ROG STRIX X870E-E and 9800X3D - Massive Packet Loss
marcel151
I also opened a case (E24110026198-0001), but maybe someone experiences the same problems. My new X870E-E (newest 0606 BIOS) has problems with the internal LAN adapter. Currently it's connected via Gigabit connection, but that  shouldn't cause problems, at least would be very bad if you would have to connect it via 5 Gb/s LAN. It seems to work normally at first, a speed test maxes out my internet connection (1000/500) and ping also is good in speed test. While playing online games, I got massive packet loss issues (while having jumping ping times), competive games are unplayable. When I try to use WiFi or external USB LAN adapter the problems are gone. So I uninstalled the current ASUS LAN driver V1126.16.1121.2023 and let Windows install a driver, which is way older. But with this old driver everything works fine. I can reproduce the problem, when installing new driver again the packet loss problems reappear.
Does someone have similar problems with the new driver? What could that be?
156 REPLIES 156
With the stock windows driver, I’m getting 1gb speeds which is the speed of my internet however, I’m unable to play any online based game. I don’t have software to test packet loss but that is my guess.
with the actual driver, computer is BSOD’s often along with basically no internet. Takes 10 minutes to load google . Com.
im leaning to a return and buy a new one or up to the hero either which has the intel mic and this realtek.
Then we also do have different issues. I have no issues at all with default windows driver. Nevertheless, ASUS has to check that. Please also open a case at ASUS even if you return your board.
Can You share link where i should report it? Ive sent email to Asus with this problem yesterday. Im using wifi now as there is no problem with it but its not samd as cable…
I will report to asus. I think my lan chip is basically DOA.
I also ran internet testing. With correct driver, I’m getting 22-25% packet loss and generic driver 12-15% loss.
Yeah the board is dog poop, also has windows 11 issues with BSOD with newest update to the point that windows doesnt allow you to update to it. Same issue with the Asus Hero x870e board. So I am just going to return mine to the microcenter tomm and get a Gigabyte or Asrock board, screw Asus.
CombinE54
Realtek lan adapter is basically not working on my x870e hero board - installing the correct drivers leads to 100kb speeds. Intel works fine though.
Yeah no way Asus did not know about this HUGE problem with the Realtek NIC/Drivers on all these x870e boards. They knew and they pushed them out anyway. Ill never purchase another Asus product.
Can You give me link to Intel adapter i should download? And u got no problems with packet loss or anything like that?
If you don't have an Intel NIC you won't need the driver.
My reproducible packet loss results. Doesn't look like much, but Online Gaming is not possible. Even if Ping times do look the same. No issues with standard driver and Gigabit connection for me, though. ASUS, you'll need to do something.
