Is there anything updated about flbk problem?
human3452
Im using rog strix b650a gaming wifi.
Recently(2 days ago), I'm experiencing the bios flbk flashing problem
https://rog-forum.asus.com/t5/gaming-motherboards/flbk-flashback-led-blink-computer-no-boot/m-p/1073...
Like this one. Is there anything updated info about it?
Jiaszzz_ROG
Customer Service Agent
Hello @human3452
Thank you for reaching out to us.
Sorry for overlooking this thread and for any inconvenience it may have caused.
According to the relevant instructions in [Motherboard] How to use USB BIOS FlashBack™?, the BIOS Flashback indicator light will only blink during the BIOS update process.
If you have already ensured that all power cables are properly connected, the CPU is correctly installed without any bent pins, and there are no issues such as an overly loose or tight installation, yet the system still fails to power on even with minimal components connected, we recommend considering a repair service for further diagnostics.
Additionally, I have DM you. Please check your inbox in the upper right corner at your convenience.
