2 weeks ago
Hi all,
Looking for help with a frustrating issue on my AM5 build. My system runs perfectly for days, then randomly typically after being powered off all day it enters a boot loop. The system turns on, fans spin for a second or two, then it powers off and repeats endlessly. No consistent Q-Code is shown, it varies or shuts off too quickly to read.
Here’s my build:
What I’ve done/tried:
This issue only occurs on this ASUS board no issues when using a Gigabyte AM5 board.
Has anyone run into something similar or have insight into this behavior? Could this be a board-specific hardware issue?
a week ago
Hello @Epicgamer347
Thank you for reaching out to us.
Could you please clarify if this issue occurred after the PC was first built or after using it for some time and occurred following any recent changes, such as a BIOS update or component replacement?
Based on your description, it appears that the issue occurs randomly. May we ask if you have observed any specific scenarios or steps that tend to trigger the problem more consistently?
What is the part number of the RAM modules you currently installed, and are they listed in the ROG STRIX X670E-E GAMING WIFI QVL?
Please also specify which slots your RAM, GPU, and SSD are installed in, as well as ensure there are no bent pins in the CPU socket, and confirm that the CPU is installed appropriately.
As the issue seems to occur frequently and is reproducible, we kindly ask that you provide a more detailed scenario description along with a full video recording that captures the problem, including the bare board test and results from minimal hardware configuration.
