Crosshair VIII Extreme Thunderbolt firmware update
boorya
External USB4 drive won't work in 40GBps/PCI-E mode when connected TB4 ports on motherboard and falls back to 10GBps/UASP.
Intel JHL8540 on my motherboard has NVM version 28 (that's very old), and there is at least NVM version 36 for this controller.
I believe that is the reason of failure.
The drive works with 40GBps speed on other devces, like Macbook Air (2022) and Dell XPS 15 (2021).
Is there a way to update this firmware? I know that ASUS does provide updates for thunderbolt firmware on other motherboards.
I tried to contact support, they were of no help. case E23120048640-0001
ROG CROSSHAIR VIII EXTREME BIOS 1402
Windows 11 22631.3078
Thunderbolt drivers 1.41.1379.0
JEYI TB2464 ASM2464PD firmware 231204850000
24 REPLIES 24
Jiaszzz_ROG
Customer Service Agent
Hello, @boorya
After consulting with the relevant departments, we have confirmed that the value of Max Payload Size is related to the PCI Express transmission efficiency.
The MPS value is the result of automatic negotiation between the device and PCIE, and a larger MPS value does not necessarily indicate better performance.
The JHL8540 specification defines a corresponding payload value of 128 bytes, and we have determined that this is a specification limitation.
Due to the ongoing regional holidays, my responses may be slightly delayed.
Thank you in advance for your patience.‌‌‌‌ 🙂
Thank you so much for your help,
I hope that NVME36 version of thunderbolt controller firmware will eventually pass the QA and will become a part of a stable BIOS version for my motherboard (after all NVME36 is nothing new, and is already a part of release versions for so many ASUS motherboards).
Please pass my gratitide to the team behind motherboard firmware, it just feels so great to be heard 🤗
fcueto
I am facing the exact same problem described by boorya.
The extreme motherboard variant are always left behind when it comes to firmware updates.
Can you please ask the motherboard bios team to include this NVME36 TB4 firmware update in the next stable release of the BIOS ?
Thank you very much.
boorya
Stable BIOS version 1505 updates thunderbolt NVM to latest 38 version, although it's not mentioned in changelog.
Custom version is no longer needed.
fcueto
This is great news !
