ASUS ROG Strix B760-F - Power Led just lights up shortly once per power-on
M1buKy0sh1r0
Hi, I have a brand new B760-F board. System is running, but I got a strange behaviour on Power LED.
At power-on the Power LED just lights up shortly and gets dark as long as the system runs. I connected the Power LED to the 3-Pin connector (no pin in the middle) on the bottom right and also tried the 2-Pin connector on the top left of the Pin-Connector.
The result is still the same.
The Power LED also does not become blinking state when system is in sleep mode.
As the system is running without other issues it seems just a Power LED power issue.
Any hints?
Cheers
M1buKy0sh1r0
1 ACCEPTED SOLUTION
Accepted Solutions
M1buKy0sh1r0
Oh dear, that's a bit embarrassing, but I seem to have deactivated the standard LEDs in the BIOS when using AURORA LIGHTS. Well, I was able to solve it myself. But here as a note for someone who is interested.
M1buKy0sh1r0
Jiaszzz_ROG
Customer Service Agent
Hello @M1buKy0sh1r0
I'm glad you were able to pinpoint the problem.
If you encounter any power management issues next time, in addition to checking for system updates and the relevant limitations in [Windows 11/10] Change Power mode and plan, you can also refer to the BIOS Manual to ensure the settings meet your needs.
As the local holiday is ongoing, there may be further delays in responses.
We appreciate your patience in advance.
Hi @Jiaszzz_ROG, thanks for the feedback. I am building my setups since my youth but never had such granular settings in BIOS yet. 😅 So just need to get familiar with it.
Cheers
