01-13-2024 05:26 AM
Hey, I have the following Problem:
Out of a sudden, without any changes, my system is not starting up properly anymore. It worked for over half a year without any problems, until two days ago:
So I made a new USB Stick with the current 2214 version of BIOS and plugged in the USB Stick exactly at that time frame between PSU Power on (Step 3) and Flashback LED blinking.
It worked. BIOS 2214 is running on my B650e-i now. It posts and the build is functioning.
But the problem with no boot still persists, if I am not following the exact steps I mentioned before:
If I wait too long and the Flashback LED start to blink, pushing the POWER Button has no effect.
I already deassembled and reassambled the whole build. No effect.
Build on Version 2214 BIOS
01-14-2024 11:01 PM - edited 01-14-2024 11:09 PM
Hello c0c01
Some are saying enabling ErP Ready (S4+S5) in the bios solved this particular issue for them.
01-16-2024 12:33 AM
Ok, I am confosued. This actually might have worked.
The Audio Jack LEDs now cleared after shutting down the PC by hand and I can start the PC normally. Does not change the fact, that they might be a bug or issue without it.
Thank you!
01-14-2024 11:19 PM
Thanks for your response!
Sadly this does not change anything. The blinking on Flashback LED still occurs after turning off and the PC won't start unless I follow the procedure explained in my post above.
01-15-2024 06:15 PM
Hello, @c0c01
Could you specify which BIOS version it was updated from to reach 2214?
After completing the BIOS update, does clearing CMOS help resolve the issue?
Or is it still necessary to switch the PSU off and press the power button before the BIOS Flashback LED begins flashing again to power on?
During the failure to boot, are there any Q-LED indicators on continuously?
If possible, could you provide a comprehensive video recording of the issue to help us better understand your situation?
01-16-2024 12:40 AM - edited 01-16-2024 12:53 AM
01-16-2024 04:47 PM - edited 01-16-2024 04:53 PM
Hello, @c0c01
Could you help in confirming the following information to facilitate further verification of this issue?
- You mention that this anomaly occurred "two days ago."
Before this anomaly occurred, were there any software or hardware changes? For example, BIOS updates, Windows updates, or connecting external devices.
- Could you provide a comprehensive video recording?
The recording should include the inability to boot after adjusting to the default BIOS settings, with the BIOS Flashback LED flashing and requiring switching the PSU switch to power on.
Then, re-enter the BIOS, enable, and save the ErP Ready (S4+S5) setting. After shutting down, it can start normally without switching the PSU switch.
- After completing the recording, could you try re-flashing the 2214 BIOS once again and see if the issue can be resolved under the default BIOS settings?
01-29-2024 10:24 PM
Hello @c0c01
Have you found a working solution for this issue?
My motherboard is different (ROG STRIX B650E-F GAMING WIFI) but I have exactly the same problem, I've done all the same troubleshooting steps but nothing helps. It also started happening out of no where without physically even touching my PC. At least your workaround does let me boot into windows, but it's annoying to do that every time.
02-19-2024 05:15 PM
Hello, @dodas
Due to the ongoing local holidays in our area, my response time may experience delays.
I apologize for any inconvenience the delayed replies may have caused.
May I ask if the situation you described happened after any changes were made? For example, adjusting the BIOS settings or connecting an external device
Could you please provide more detailed information about the issue, including the specific problem, when it occurs, how frequently, and the troubleshooting steps you have already taken?
Hello, @Rad1
May I ask what the model of your current motherboard is?
Providing this information will help us better understand your situation and assist you more effectively.
02-20-2024 01:32 AM
same as the topic, rog b650e-i
now doesnt start, cmos clear works for 15 mins in windows 11... then restart and same problem
i try with corsair 750w instead of loki850w and same result, fans are going fast... and slow... and ramled orange stuck and nothing happens
i contact with asus support and ram is compatible as ssd...
