11-06-2025 08:17 AM - edited 11-06-2025 08:25 AM
I'm having issues with an otherwise fully function Rode NT-USB microphone on two different Asus AM5 motherboards. I originally had an Asus ROG Strix B650E-F Gaming Wifi board, observed this issue, returned the board, and got an Asus TUF Gaming B650E-Plus Wifi board as a replacement, which I'm using now. The other potentially relevant parts of my build are an AMD Ryzen 7 7800X3D, 2 x 16 GB = 32 GB of DDR5-6000, and Windows 11 (though the issue is also present on Windows 10).
My microphone has its own headphone jack, and therefore works as both an input and an output device. As you can see from the video below, when it's connected to either of my case's front panel USB3 ports and selected as the output device, it disappears and reappears repeatedly from the Settings app in Windows 11, while audio cuts in and out.
This behavior is exclusive to the front panel USB3 ports. The microphone works fine as both an input and output device when connected to a rear USB2 or USB3 port. Another separate issue is that it's not working with the Bios Flashback port, which I understand should behave just like any other USB port. Using that port doesn't result in the device disappearing and reappearing, but there's no sound other than a faint clicking.
Things I've already tried:
Other relevant information:
I'm all out of ideas - thanks if you can help!
