06-28-2024 10:38 AM - edited 06-28-2024 10:41 AM
When activating HDR with firmware 105 the proximity sensor stops working, it remains marked in grey in the menu, which did not happen with the previous ones and it worked without problems.
The only solution I have found is to activate the adjustable brightness option, then it does work. A warning appears that the HDR curve will be modified but I understand that if you do not modify the brightness it will remain the same. I understand that it is a bug that I ask Asus to take note of so that future firmwares can fix it.
Thanks
07-03-2024 12:55 AM
Hi @Pepillo ,
according to your question, when the HDR feature is enabled, the proximity sensor will not function. This is an expected behavior.
You can refer to the diagram below or consult the manual for further information.
If you want to adjust the brightness while HDR is enabled, please go to Image > HDR > Setting > Brightness Adjustable.
07-03-2024 05:23 AM
Thanks for answering @Aureliannn_ROG, but either I didn't explain it well or you didn't understand me.
1.- Before firmware 105 the proximity sensor worked with HDR mode.
2.- If you activate the adjustable brightness option, the proximity sensor works again with HDR mode, just by activating it without changing the brightness.
07-04-2024 10:46 AM
How exactly does using HDR prevent a proximity sensor from working? This really sounds like a bug, not a feature. What next? When running the monitor at 4K the following features are not available: Displaying image, turning on, turning off?
07-09-2024 03:43 AM
The proximity sensor doesn't work with Dolby Vision either. It would be nice if they fixed it, remember that before firmware 105 the proximity sensor worked in all modes, it doesn't make sense that it doesn't work depending on the mode.
07-09-2024 10:41 PM - edited 07-19-2024 03:05 AM
The same thing happened to me. I don't know how, but now it is solved.
