Pixel Cleaning and Burn-in issue
Mtrdk
TLDR: Bought a PG27AQDM as a birthday gift back in January and began using it around the end of May, now the screen has insane amounts of burn in just by turning the monitor on and using it for a short time 5-10 minutes and the pixel cleaning seems to be stuck or at least not working as it just keeps flashing and I don’t know where to get help.
Info:
I am a PC Gamer and I am running the below mentioned build. I have lowered the brightness to try and combat this issue (In the monitor settings and in AMD Adrenaline) as it has gotten worse and worse by the day since I got it, never had a OLED so I did not know if this was / is normal. I would have to do at least 1-5 pixel cleanings after a 3 hour plus gaming session to make sure it was completely clean.
PC:
7800x3D
7900 XTX
X670E-F
Using DP Cable from Monitor to PC. It also seems like the screen is not correctly coloured as it is very white ish.
Am I the only one with this issue?
Nate152
Hello Mtrdk
I haven't experienced any burn-in with my PG27AQDM and I use it a good bit every day.
Try running the pixel cleaning again, the pixel cleaning takes approximately 6 minutes to complete.
You could try "All Reset" in the monitor's OSD settings.
