PG39WCDM | Locked / Greyed-Out Color Temperature and Color Saturation options in HDR
PG39WCDM-USER
Hello, I own a PG39WCDM and PG34WCDM. The latest Firmware Update for the PG34WCDM unlocked the ability to calibrate the monitors Color Temperature / Saturation in HDR allowing one to calibrate the images color temperature and saturation appropriately.
The PG39WCDM's MCM103 FW Update, on the other hand, never solved this issue. The option to calibrate the Color Temperature and Saturation while having HDR enabled on the PG39WCDM are locked out; greyed out and inaccessible.
Can we get a Firmware Update for the PG39WCDM to enable these options just like it happened in the latest Firmware Update for the PG34WCDM?
It's been very frustrating seeing a good monitor reduced to paper weight because of a forced yellow/orange color temperature and washed-out colors in HDR.
Again, can we get a Firmware Update for the PG39WCDM to enable these options just like it happened in the latest Firmware Update for the PG34WCDM?
Thank you in advance.
0 REPLIES 0
