PG32UCDM - how to have sperate settings for console - using two inputs?
Spikecast
Hi there,
Recently purchased a PG32UCDM and I'm using an nvidia 4060 via HDMI 2.1 cable to this screen and also a PS5 slim to the second HDMI. I am wanting to use the console HDR setting for my PS5 and gaming HDR setting for my PC but I have to keep using the OSD to change the setting as it's no doing it for each input. Is there a way around this?
Thanks in advance!
6 REPLIES 6
Ishavet
I am having a similar issue but with DisplayPort and USB-C input (I tried HDMI and it's the same there as well). I wonder why this monitor cannot save the input settings. I have to manually redo them every single time and some changes do not register at all, even when I pick them manually. (https://rog-forum.asus.com/t5/rog-series-monitors-pg-xg/pg32ucdm-does-not-save-image-settings/m-p/10...)
Do your inputs at least stay the same when you just restart using your PC or the console? Because mine doesn't even do that. (For example if I pick a different kind of HDR or Dolby Vision mode, it always defaults back to "Dolby Vision Bright" or "Cinema HDR" respectively after a restart or even a new game start etc.)
Aureliannn_ROG
Customer Service Agent
Hi @Spikecast @Ishavet ,
Thank you for bringing this issue to our attention.
We have already submitted the matter to our backend team for verification and assessment. We kindly ask for your patience during this process.
We greatly appreciate your understanding and cooperation.
Please note that response times may be delayed due to upcoming regional holidays. For urgent inquiries, please contact your local service center. Thank you for your patience.
After careful review, we have confirmed that the current Spec function only supports storing a single set of settings.
It does not have the capability to store different settings for different ports.
This means that when you modify the settings in Spec, the changes will be applied to all relevant ports.
Thank you for your understanding.
Ah, that's really unfortunate, but fair enough.
However, this still does not explain, why even *one* change is never saved. Shouldn't the monitor at least remember when I pick "Dolby Vision Gaming"? Why does it always revert back to "Dolby Vision Bright" - even without changing the input, simply by restarting the computer?
Also, if only one setting can be saved, then what is the point of the "customized setting" function? It even comes with two save slots. Yet, it just doesn't save all of the settings that I change.
Could any of this be changed with a future firmware update?
Spikecast
I've just returned mine back to the retailer today. The lack of settings saved for each input is a total dealbreaker for me. I didn't find the HDR that bright and the panel was making a high pitched noise in standby so can't justify the £1250 I paid. Back to my LG C4 42" OLED which has much brighter HDR and multiple input settings.
I envy you. Unfortunately, it's too late for me to do that. This was my first ASUS monitor, I thought I bought something premium for that price. Fool me once, I guess.
