PG32UCDM DISPLAY PORT PROBLEM
DreamAsus
Hello.  I have problem with display port. Namely it won't display screen  with notice "displayport no signal ". I have checked everything: drivers, firm cable connection  etc. I add that on my 2 other ips monitors  works perfectly with no issues.  Once picture just flashed for a moment only that's all.  It blocks automatic  input connection as well with hdmi signal.  Black screen all the time. When l unplug display cable then turn hdmi signal.  It shows in input menu that display port is recognized and connected  as well . Anyone has a clue what is wrong or it is factory fault? Monitor has the newest 108 update also.
1 ACCEPTED SOLUTION
Accepted Solutions
Thank you for your time and help. It started work. Will see for how long.  Regards.
5 REPLIES 5
Nate152
Hello DreamAsus
Try resetting your monitor.
Bring up the monitor OSD, scroll down to System Setup, move to the middle and scroll down to "All Reset" and select Yes.
How does this go?
Thank you for your hrlp. Miracly it stsrted work after sone tine. I left all setup on stsnby mode. Turned on now and bingo screen has displayed.  Probably some cspacitors were sleeping as l got this monitor for a year but now l started using display port. Many thx for your time.
metalbones
What graphics card do you have? How many monitors do you have plugged into it and how are they all connected? (DisplayPort or HDMI)
Great to hear, I’m glad it’s working. Enjoy!
