OLED PG27AQDM Firmware update MCM107 screen problem
atabrkavc99
hi guys !
PG27AQDM Firmware update MCM107 update my monitor and the screen became like this
pls help meWhatsApp Görsel 2024-08-26 saat 22.17.58_47a6b61f.jpgWhatsApp Görsel 2024-08-26 saat 22.18.02_05cec5d8.jpg
da_Choko
Well that´s the most cliché answer but try turning it off and on again.
Aureliannn_ROG
Customer Service Agent
Hi @atabrkavc99 ,
Thank you for providing the detailed information.
Regarding the screen tearing issue you mentioned after updating to firmware 107, we suggest you try the following steps:
  • Restart the monitor: Turn off the monitor, wait a few moments, and then turn it back on. Restarting can clear the monitor's temporary memory and sometimes resolve temporary software glitches.
  • Restore factory settings: Enter the monitor's OSD menu and find and select "Restore factory settings" or a similar option.
    Note: Restoring factory settings will reset all the monitor's settings to their default state, so please back up your customized settings.
  • Check the connection cable: Ensure that the connection between the monitor and your computer is secure and try replacing the connection cable.
  • Update the graphics card driver: Go to the graphics card manufacturer's website and download and install the latest graphics card driver.
