Help: PG27AQDM max 120hz, no 240hz option.
Crasje
I just installed the  PG27AQDm and the PG34WCDM monitors with HDMI 2.1 48GBS cables
I can run PG34 on 240Hz, but not the PG27
i have the rog strix 3080 gaming.
Anyone any suggestions?
Corsair 3500x
Corsair HX1200i
Asus ROG Maximus Z690 Extreme
Intel Core i9-12.900k
Corsair H150i Elite Elite LCD XT
Corsair DDR5 Dominator Platinum RGB 2x32GB 5600Mhz
Samsung 980 PRO 2TB M.2 SSD (2x)
ROG RTX3080-O10G-Gaming
Monitor 1: ASUS ROG Swift PG34WCDMC
Monitor 2: ROG Swift OLED PG27AQDM
ROG Strix Scope II 96 Wireless
ROG Spatha X
Windows 11
10 REPLIES 10
Crasje
I have seen that a lot of people use the display ports, but also that hdmi 2.1 does the job.
help!!
Corsair 3500x
Corsair HX1200i
ROG Spatha X
Windows 11
Crasje
Help!!! 😁
Corsair 3500x
Corsair HX1200i
ROG Spatha X
Windows 11
emiljensen2
The port on this monitor is only hdmi 2.0
Nate152
Hello Casje
The HDMI ports on the PG27AQDM are HDMI 2.0.
The HDMI ports on the PG34WCDM are HDMI 2.1.
Try the displayport cable that came with the PG27AQDM.
Hi, since my 27" is on the left, and my PC on my right it is to short.
Online I read to go for the DP 1.4, what are the specs for that cable I should look for?
Thank you!
Corsair 3500x
Corsair HX1200i
ROG Spatha X
Windows 11
Ok, so the DP2.1 cable is backwards compatible with DP1.4 🙂
(since the HDMI 2.1 cable is not with HDMI 2.0)
Corsair 3500x
Corsair HX1200i
ROG Spatha X
Windows 11
Nate152
Both are backwards compatible.
You get more bandwidth and a higher data rate with Displayport 1.4 vs HDMI 2.0.
I Needed a longer cable too, so I just went with a Displayport 2.1 cable.
Hi Nate,
If  2.1 is backwards compatible with the 2.0 then why doesn't my cable work? It supports up 48Gbit/s? Should it then also not provide 240hz?
Or is it that HDMI 2.0 can't provide 240hz and there is a port on the monitor that doesn't support it's own capabilities?
I already ordered the DP1.4 cable 😀
Corsair 3500x
Corsair HX1200i
ROG Spatha X
Windows 11
