10-24-2024 06:59 PM
Hi
I'm having an annoying issue with my ASUS ROG Swift PG27AQDM monitor and its firmware.
Ever since MCM106 firmware (106, 107, 108 and latest 109), when my monitor goes into sleep mode it disconnects or something from Windows/PC. Because when I come back and wake it up, apps have forgotten which my main monitor is and opens up on my 2nd monitor.
It's like when it sleeps, apps starts moving to the 2nd monitor. Qbittorrent and STEAM for example. I also think a similar thing is happening when I tab out of a full screen game or when I close it (when it goes black).
Now to be very clear. This does NOT happen at all on MCM105. I tried upgrading from 105 every time there is a new firmware over the last year and every time the issue comes back and disappears as soon as I go back to 105.
Does anyone have any idea of what's going on and more importantly, how to fix it. I tried to reset the monitor multiple times. Before and after a firmware upgrade. Does not help.
PC:
Case: Fractal Design Torrent Black Solid
Case Fans: 4x Noctua NF-A12x25 PWM Chromax
MB: ASUS ROG STRIX X670E-A GAMING WIFI
PSU: ASUS ROG Strix 1000W Gold Aura Edition
RAM: G.Skill Trident Z5 Neo RGB DDR5 6000MHz CL30 32GB
Storage: Kingston Fury Renegade M.2 2TB SSD
CPU: AMD Ryzen 7 7800X3D
CPU Cooler: Noctua NH-D15 Chromax
GPU: MSI GeForce RTX 3080 GAMING Z TRIO 12G LHR
Monitor 1: ASUS ROG Swift PG27AQDM 27" 240Hz 1440p OLED QHD
Monitor 2: ASUS ROG Swift PG279Q 27" 144Hz 1440p IPS G-SYNC
Headset: Audeze Maxwell
Mic: Blue Yeti X
Keyboard: Wooting Two HE
Mouse: Razer Viper V3 Pro Wireless
Mousepad: 4114 AERO - LEGACY
OS: Windows 11 Pro x64 (24H2)
Bandwidth: 1000/1000
10-25-2024 01:48 AM
Hi, unfortunately the problem is not solved yet with Firmware 109, there is an open discussion on this problem.
PG27AQDM Stand-by bug
If you want some advice, stay with the Firmware 105 version because most likely ASUS technicians will never solve this problem..
10-25-2024 04:09 AM - edited 10-25-2024 04:10 AM
Oh. I didn't know it was a known issue. But that's good I guess, that it's not just me having it.
But in the thread you posted, the last post sayts its fixed..
10-25-2024 05:01 AM
This has been fixed "MCM109 resolves the occasional signal loss when toggling HDR" but not the kind of problem we have.
10-31-2024 07:33 PM
Hi @Ejziponken ,
Thank you for contacting ASUS support.
We understand that you are experiencing an issue where your PG27AQDM monitor's primary display is not recognized after waking from sleep mode. To better assist you, we would like to clarify a few points:
With this information, we will be able to analyze the problem more thoroughly.
10-31-2024 07:50 PM - edited 10-31-2024 07:58 PM
First of all, I don't think "monitor's primary display is not recognized after waking from sleep mode" is the correct description. Once the monitor is woken up, It is the primary display without user input. But the APPS do not recognize this by themselves. So I have to start moving the apps from my 2nd monitor to my main one after each sleep mode.
Whatever happens, is happening once the display goes into sleep mode and reverts once woken up.
Display recovery: Both monitors wake up normally when the mouse is moved. I don't need to do anything.
Occurrence: Not that I have seen. It does behave normally when being used.
Problem recording: Not sure what you want me to record.. I mean, it happens in sleep mode.
Display driver: Using latest
Monitor settings: I did reset about 15 times over the past year. Also, since others have the same issue, I don't think we can blame it on a bad cable.
PC:
Mic: Blue Yeti X
Latest drivers and firmware for everything.
11-03-2024 05:24 AM
For me the same with DP 1.4. After booting i have to turn off and on my monitor to see my windows screen and I can't boot into my bios with DP 1.4. My CPU is an i9 13900kf and my bios set it to 3 ghz, when I set it to 3,1 ghz or higher my screen is working again. I tried to update the firmware with the onekey update and with the usb drive, sometimes windows showes an incompatibility software message with the update tool.
GPU is kfa2 NVIDIA 4090
CPU is i9 13900kf
Motherboard is MSI 790 Tomahawk DDR5
RAM is Corsair DDR5 5200 32gb dual kit
PSU is ENDORFY Supremo FM5 Gold 1000W
Case is phanteks eclipse g500a performance
CPU cooler is arctic liquid freezer iii 420
SSD is a 2tb Kingston m.2
I try to keep my firmware and software as updated as possible.
11-07-2024 11:32 PM
Hi @Ejziponken,
Thank you for providing the detailed information. It is very helpful for us to resolve the issue.
To better understand the issue you are experiencing, we would like to confirm a few points with you:
Providing the video will help us locate the problem more quickly and find the best solution.
Thank you again for your cooperation.
11-16-2024 06:58 AM
Confirmed, since firmware MCM106 and later, every time the PG27AQDM enters sleep mode (indicated by an orange light), such as when switching between two screens with the Win+P shortcut, it emits the typical "disconnection sound" from Windows upon reactivation, and some my windows apps are relocated. This issue does not occur with firmware MCM105.
11-16-2024 07:52 AM
The monitors are good for sure when u like the design but the software is buggy as hell and i think they will never be able to fix this like Microsoft is doing it with Windows 11. Even not good enough to be at beta stage.
