ROG SPATHA Does Not Work in Wired mode [Resolved]
MLGbr
My system: Win7 sp1 64 bits (updates disable since november 2017) + ROG Armoury v10226 (last version)
I've always used the mouse in WIRED mode, but...
=== THE EVENT
In 01/19/2018 00:51 (UTC -3) the mouse started to fail, I thought it was cable problem.
15 seconds later, it stopped working in wired mode.
=== SYMPTOMS
With the SAME CABLE in the wireless base, the mouse works in wireless mode.
In cable mode:
a) Irresponsible mouse
b) ROG ARMORY does not detect anything
c) Windows detect 2 hardware items 'Mouse compatible with HID'
d) Uninstalling and Installing ultimate version of ROG Armory did not provide any change in the outcome symptoms.
The SAME CABLE, removing of mouse and putting it in the WIRELESS BASE, and...
a) Windows detect 4 hardware items 'Mouse compatible with HID'
b) Sometimes the ROG armory detects the mouse, sometimes not.
--Behavior Ambiguous / Unpredictable--
Test 1
ROG ARMORY show message: "You also need to update the mouse firmware. Switch to THE WIRED connection mode to update the mouse firmware." I NOT update and not detect mouse in "mouse" tab, BUT in the settings says: Version Software 1.02.26 | base firmware: 1.32 | mouse firmware: 1.49
Test 2
ROG ARMORY detect Mouse, and show Mouse options in "Mouse" tab.
In the settings says: Version Software 1.02.26 | base firmware: 1.32 | mouse firmware: 0.00
Mouse is detected in Wireless mode, and I can reprogram the functionality of the mouse buttons.
I tested the sync buttons, or closed and reopened ROG ARMORY, but it did not change the symptoms.
CONCLUSION
a) If I am using the same cable, connected to the same USB port, it is clear that the cable is perfect.
b) The behavior of ROG ARMORY does not seem predictable, it can not be said why it detects the mouse, or why it in another test does not detect the mouse.
c) There may be a correct sequence of procedures, so that you can perfectly detect the mouse in ROG ARMORY, but there is no exact documentation.
d) ROG ARMORY software expects the user to have a specific update to Win7 and I do not have it?
MY OPINION:
I noticed that ROG ARMORY is automatic updates 'by default' . I'd never realized, if I did, I'd have disabled.
On 01/19/2018, when I turned on the computer, ROG ARMORY did an automatic update.
As Windows did kernel upgrade involving Meltdown / Specter, it is possible that 'The Peripheral Team of ASUS' has updated the ROG ARMORY,
assuming ALL users would upgrade Windows, which is not true, and problems are happening.
If you have any procedures, or any updates that solve the problem - Show now
23 REPLIES 23
Mr administrator: IT IS IMPOSSIBLE TO UPDATE MOUSE FIRMWARE IN CABLE MODE!
I will draw
Step 1 - Put Mouse on the cable
71463
Step 2 - Open ROG ARMORY
71464
Step 3 - Live Update
71465
Crash!!
71466
EVENTVIEWER
71467
STATUS:
Wireless - OK
Wired - Not Work
MASSIVE LOGS HERE - From the beginning of the problems
https://www.dropbox.com/s/f64euplin26dngv/MyLogs.7z
I hope to help the ASUS peripheral team, In particular, the ROG ARMORY developers team.
I will use the mouse in Wireless mode, until ASUS found a solution.
Mr administrator: Do you want me to open a post "Rog Spatha does not work in wired mode", or can we continue here in this post?
HOW THE WIRELESS PROBLEM WAS RESOLVED
I bought a Corsair keyboard, and I installed the Corsair Utility Engine (CUE) version 2.20.72 on 12/18/2017.
A perfect month later (01/19) the problem occurred in the ROG SPATHA mouse.
Several times during these days, I suspected CUE, and disabled boot during tests and in my attempts to re-enable the Mouse.
But during the normal use of everyday life, I allowed CUE to be run in Windows start.
Between the dawn of 01/19/2018 and the afternoon of 01/07/2018, the wireless base was detected, but the mouse was not detected by ROG ARMORY, not being able to reprogram the mouse buttons in Wireless mode, although the simple operations of clicking and moving the cursor worked.
I do not have a screenshot, but in Wireless ROG Armory mode it did not display Mouse information, it only showed a reddish background.
( It is not the real screen, it's just a similar drawing of SPATHA in wireless mode, without detection by ROG ARMORY )
71515
INVESTIGATION - RETURN OF WIRELESS OPERATION
-Computer was shut down on 02/07/2018 at 03:30:20 (UTC-2), still with all problems
-Computer was connected on 02/07/2018 at 18:27:57 (UTC-2)
-Corsair Utility Engine (CUE) version 2.20.72 if run at Windows startup, and displayed a black popup saying there were updates.
-I opened the CUE application, and I used its graphical interface, to cancel any kind of update, but there was no option to cancel, and I ended up making no changes.
I was completely involved with the problems of the mouse, and I did not want this application to disturb me.
-CUE may have carried out some procedure without my consent. I've never updated the CUE application.
The ROG SPATHA mouse was detected again in wireless mode, allowing button programming and light change, even using the old ROG ARMORY version 10224.
I made a printscreen - SPATHA is complete detected in Wireless mode
71516
-I updated the ROG ARMORY for version 2.04.04 on 02/07/2018 at 18:51:29 (UTC-2)
- After updating, the ROG SPATHA continued working perfectly in Wireless mode.
Then, I performed the procedure of opening the mouse and disconnecting the battery (as requested by the forum administrator), and I answered writing the post #7 in this thread.
The correction of the problem of the ROG SPATHA Wireless occurred on 02/07/2018, between 18:27:57 and 18:51:29 (UTC-2), AND I AM SURE THAT IT WAS CAUSED BY AN "unknown remote procedure" of Corsair Utility Engine version 2.20.72, which I did not order, and never allowed, and occurred when the application detected an online update (which I never asked to do).
- CUE is in version 2.20.72 in my PC, it is the same version that I installed on 12/18/2017, and officially no update occurred.
71517
MY ANALISIS
File changes at critical moment, between the 'mouse correction event' and the ROG ARMORY update
"user-PC" is my local user
PATH - Data - Hour (UTC-2) - Size - User - FileName
--18:34
C:\Users\user\AppData\Roaming\Corsair\CUE
07/02/2018 18:34 user-PC\user Corsair
C:\Users\user\AppData\Roaming\Corsair\CUE\Corsair
07/02/2018 18:34 365 user-PC\user CUE.cuecfg
07/02/2018 18:34 user-PC\user ..
Comment: Files produced by CUE, automatically or during my access, although I have not made any changes
Corsair modification files at 18:34
71518
There may have been changes in the Windows registry, I have no way of knowing.
--18:48
C:\Users\user\Pictures\2018-01-23
07/02/2018 18:48 67.565 user-PC\user TelaFuncionando.JPG
Comment: ROG SPATHA was working perfectly in wireless mode with ROG ARMORY v10224, and I did a screenshot using SnippingTool from Windows 7
C:\Users\user\AppData\Local\Microsoft\Windows\History\History.IE5
07/02/2018 18:48 user-PC\user MSHist012018020720180208
C:\Users\user\AppData\Local\Microsoft\Windows\History\History.IE5\MSHist012018020720180208
07/02/2018 18:48 user-PC\user ..
07/02/2018 18:48 0 user-PC\user container.dat
Comment: I never use Internet Explorer, it must have been opened as embeded by some other application, must have saved history when it was closed.
SOFTWARE ANALISIS
The application's XML may indicate an attempt to identify a Scimitar mouse.
Opening the configuration files, at the end of the file
C:\Users\user\AppData\Roaming\Corsair\CUE\profiles\"UNIQUE ID".cueprofiledata
71519
I have a Corsair keyboard, but I've never had a Scimitar.
Perhaps this is the source of the all problems: Attempting to execute "Demo" in other hardwares.
I removed CUE from the startup.
NOTE: The Wireless Problem has been solved, but the mouse continues to have problems in the wired mode.
MasterC
Community Admin
Community Admin
As mentioned previously, please wait until the Live Update feature is ready. When it is, you should be able to update your firmware. From there we can we can determine what to do next. Version 2 of Armoury was actually not supposed to be available to the public last week.
_____________________________________________________________
FPS, Racing, and VR Gamer / Tech Enthusiast / ROG Admin
ROG SPATHA STATUS:
Wired: Intermittent detection (less than 2 seconds)
Wireless: Perfect Operation
Connecting the ROG Spatha to the computer in wired mode, with ROG ARMORY 2.04.04 opened - Every 30 seconds Windows seems to try to detect it, but can not,
as if the mouse was connected for 2 seconds and then disconnected.
Windows does not recognize
71690
Windows recognition only 2 seconds
71691
And return to 'not-recognize normal situation' for 30 seconds
71690
After some detection attempts, the behavior stops for a few minutes (leaving the mouse completely dead), and returns again.
Does the administrator have any ideas?
What about the mysterious ASUS RMA in Brazil?
After a purchase, how many months does ASUS allow the user to do RMA, with a Brazilian shopping in a store in Brazil?
The manual of the Mouse says "1 month for the physical store", and supposed 6 months given by the Asus brand - It is possible that this guarantee should not be valid in Brazil, neither ASUS staff can answer that.
I tried to go from behind the RMA and had a brutally negative experience.
If the mouse problem is not solved, I'll be posting here what happened.
MasterC
Community Admin
Community Admin
Sorry the Live Update has been delayed until next week. It is best to wait for that before trying RMA.
For more info about RMA:
https://rog.asus.com/forum/showthread.php?34832-ASUS-Worldwide-RMA-Guide
MasterC
Community Admin
Community Admin
The new Armoury II (2.04.07) is now available, please try it by going to this thread to download:
https://rog.asus.com/forum/showthrea...ny-issues-here
1) I downloaded Rog Armory 2.04.07 zip file and unzipped into a folder
2) I connected the mouse Rog Spatha on the cable
2b) I use another common mouse to operate the computer
3) Close all Rog Armory executables (ArmoryLiveUpdate.exe, ROG Armory.exe, Mutually Exclusive Aura Agent.exe, MacroAgent.exe) and taskeng.exe
4) Execute Setup.exe of installation
5) I confirmed the uninstallation of Rog Armory previous version.
6) The installation closed and nothing happened.
7) Execute Setup.exe again
😎 Installation occurs normally, and prompts you to restart
9) Restart computer
10) Execute Rog Armory (from desktop Link) as administrator
11) Rog Armory detects Rog Spatha mouse.
11b) The mouse pointer slowly slides to the right and down.
12) I make the mouse firmware update
12b) During firmware installation, Windows emits USB connection and disconnection sound several times, but I watch it without interfering.
13) The mouse returned to normal operation
The recorded macro was lost, possibly because of the reinstallation process, but I'm very happy.
:rolleyes::cool::D;):o
MasterC
Community Admin
Community Admin
Glad everything work out!
I left the computer for 10 minutes.
When I came back,
Windows had a message that USB was not being recognized,
and Rog Spatha's mouse with the lights off.
Since surely the problem is caused by software - 100% by the ROG armory - I rebooted the computer, and the mouse returned to normal.
1) I closed all Rog Armory executables
2) Msconfig and removed "Armory live update" from startup.
3) Restart
4) I waited another 10 minutes, and everything continued normal.
The problem was solved by removing "Armory live update" from startup
It seems like a problem:
- Power management
- Some kind of TimeOut
This is a Rog Armory issue - 100% software;
The mouse working perfect without "Armory live update" from startup.
I found the final solution for the Rog Spatha Mouse.
After
1) Updating Rog Armory
2) Remove Rog Armory from Windows start
I CHANGE THE USB PORT !!!
Windows detected the mouse, did the installation, and now it works perfectly.
Never again of problem of bad detection.
100% solved!!! 😄
