ROG KERIS WIRELESS AIMPOINT PROBLEM
Delamaine
Hello, mouse worked fine a few days ago and suddenly whenever I leave the mouse idle or change from 2.4 to wired, DPI switches to default so I have to keep switching it through the dpi button.  Already tried resetting the mouse and already updated to the latest firmware (3.00.07). What should I do?
17 REPLIES 17
Nate152
Hello Delamaine
Here is what I would try.
1) Install the polling rate booster firmware update. - ROG Keris Wireless AimPoint | Gaming mice|ROG - Republic of Gamers|ROG Global
2) Install the ROG Omni Receiver firmware update.
3) Check for updates in Armoury Crate.
4) Set the dpi in Armoury Crate.
Nope already tried that. Even if I try changing DPI 3 to 800 DPI, If i try leaving it on idle or switching to wired it reverts to 1600 DPI. Also tried downloading ROG polling rate booster but the "YES" option is greyed out. Also tried safe mode and still the same. This might be a hardware issue. Any thoughts?
AS08
In armory crate click on devices and select your rog mouse and then set your mouse dpi there
Problem is if I set it to DPI 4 and leave it on idle, it reverts to dpi 3. Even tried setting dpi 3 to 800 and it still reverted to default dpi 3 1600 but armoury crate says its 800
Nate152
Nate152
Nate152
Nope, settings work until I go idle or switch to wired mode. Mouse goes back to default settings but armoury crate settings stick.
MasterC
Community Admin
Community Admin
Could you go to User Center and try disabling this?
_____________________________________________________________
FPS, Racing, and VR Gamer / Tech Enthusiast / ROG Admin
