Looking for parts ROG Spatha
Andy0679
I'm trying to find the piece to stand the charging dock up for the ROG Spatha X mouse. I bought it used and it's missing the foot. The case, spare switches and tool as well but those I can do without. I would however like to find the foot for the dock. If anyone knows where to find it I'd be so very thankful. I've tried E-bay and it doesn't make sense to buy the entire dock and all just for the one tiny piece. Any help is greatly appreciated.
3 ACCEPTED SOLUTIONS
Accepted Solutions
Nate152
Hello Andy0679
I see the charging dock on ebay for $30.00.
I see a brand new ROG Spatha on Amazon for $49.99.
Searching the ASUS store, I don't see a charging dock or foot sold separately. If you can't find one, you can just use the cable to charge it.
Nate152
Well, it looked new, I see on the right hand side it does say used.
I see a renewed Spatha for the same price $49.99, but this one says accessories may not be original.
Amazon.com: ASUS ROG Spatha RGB Wireless/Wired Laser Gaming Mouse (ROG Spatha Gaming Mouse) (Renewed...
8 REPLIES 8
Nate152
Hello Andy0679
I'm in Canada. The only ones I saw on Ebay were used and from the UK for 48 CAD. Could you send me the link for the brand new Spatha for $49.99 on Amazon?
Nate152
Thanks for the help. I'm on the fence about ordering the dock from EBay as it'll cost me $75CAD all in. I have the main piece to charge on and it works fine laying flat on my desk. I guess it's a question of how badly do I need and want for it to be standing up. I don't think that is worth $75 so I think it'll have to do for the time being. I am now also looking for replacement battery as I noticed the stock one in the mouse now doesn't last a full day and even in idle it drains sorta quickly, roughly 5% per hour with the odd bit of brief use. I have the lighting effect turned to low light and set to go into standby off after 1 min. I did read some people are having trouble with replacement batteries not working correctly? Is there something I need to be aware of?
Nate152
Yours seems to be losing it's charge faster than normal, it should at least last two full days.
What sometimes happens is the battery swells,  I'm not sure what causes it, but could be related to unusually high room temperature. It's possible the person you bought it from lives in a warm/hot environment.
You can take the battery out and check it. If it needs replaced, you can get one here.
Original Replaces 1250mAh Battery For ASUS ROG Spatha Wireless Mouse Batterie Accumulator AKKU - Ali...
Yeah I ordered one already. I read on reddit or maybe here that after people replace their battery it works for the initial charge it arrived with but when they try to charge, the battery doesn't detect. I'll find out. Honestly it makes no sense to me why it wouldn't work. I made sure to order one that mat he's capacity.  I removed the cover off my mouse and checked the battery to see how big it was. It's labeled 1000mah so thats what I ordered. Hopefully I have no problems.
Nate152
Sounds good Andy0679.
Make sure you connect the battery cable.
Let us know how it goes when you get the new battery installed.
