Keris Wireless Aimpoint Losing Connection
leoncon99
Since I updated the Firmware of my mouse, I get weird connection issues. The mouse just freezes and is unresponsive for about 10-15 seconds. After that it works like normal. This happens very randomly and is only appearing after the last FW upgrade. Any known issues with the new FW? Is it possible to revert back to the old version? It is really annoying... Tried nearly everything. Reinstall of Armoury Crate, Reinstall FW... I use it in wired mode now and no problem so far. Only happens in 2.4Ghz Mode
55 REPLIES 55
leoncon99
On Reddit i also found someone with the same problem.
dsr
i am also having the same issue. although it happened 3 months or so ago and it seemed to have stopped, since the recent FW update its now back again. very annoying when it happens in the middle of a game and you have to quickly flick the switch under the mouse to restart it...
jAXXON32
i have the same issue and it's really annoying, cuz i only got that mouse for about a month, everything else is nice but this kinda sucks
Inerva
I also have this problem after installing the update. Perhaps someone knows how to install the old firmware version?
Megadriver_16
Same problem after last update
Nate152
FW: 3.00.05, FW Receiver: 4.00.01
I did the normal Update trough armoury crate and then the issues started. I also tried updating it with the upgrade tool but it didnt resolve the issues
Inerva
I updated the mouse firmware (3.00.05) and got a problem with the 2.4GHz connection. Then I updated the receiver to version (6.00.08) and nothing changed, the problem remained.
